Sponsored by: CARiD
yet another coolant LEVEL sensor problem
Old Aug 31, 2008 | 03:18 AM
MisfitJ03's Avatar
Default yet another coolant LEVEL sensor problem
so im having a problem with the sensor that i cant figure out. i am aware that the sensor is not needed so ill probably end up unplugging it, but i want to see if anyone has any ideas.
so ive replaced my coolant level sensor 3 times in the past year, replaced the wiring harness too. the 2nd time the sensor went bad was right after i hit a harsh bump in the road and after that it wouldnt work. the 3rd time i replaced it the thing just came on after 15 minutes for no apparent reason. when you unplug the wire the light goes off as it should and i always make sure the radiator is full. my question is if anyone has any ideas as to why these things keep breaking on me. is there something wrong thats causing the light to come on or are these things really just that crappy?
thanks
Old Sep 1, 2008 | 09:53 AM
wssix99's Avatar
Save the manuals!
Have you flushed your coolant system lately? Do they sensor elements look dirty when they come out or are they clean brass? Maybe the sensors are getting contaminated by something circulating in the coolant?
Old Sep 2, 2008 | 01:10 AM
MisfitJ03's Avatar
the coolant has not been flushed recently. every time ive pulled the sensor out its been clean brass so i dont think thats the problem, or atleast it shouldnt be
Old Sep 2, 2008 | 02:50 PM
PAGregSS's Avatar
Sounds possibly like a grounding issue. If the ground is bad, you could be shorting the sensors out.
Old Sep 3, 2008 | 06:33 AM
pjb's Avatar
pjb
mine was caused by a leaking PS cooler. It leaked PS fluid into the coolant and caused the low coolant sensor to turn on the light. Replaced the cooler, flushed both the coolant and PS, cleaned the sensor, and no more problem.
do a search for details on symptoms/tests to verify if thats your problem.
Old Sep 4, 2008 | 12:37 AM
MisfitJ03's Avatar
yea i heard about the PS leaking into the coolant. is there any way to tell if its actually leaking or not and do you know how much that part is?
thanks
Old Sep 4, 2008 | 06:36 AM
wssix99's Avatar
Save the manuals!
thanks
If one has a PS cooler leak, one would typically notice a dramatic drop off in the PS fluid level (with no visible leak) and alien slime congregating on the coolant dipstick.
Old Sep 5, 2008 | 05:52 AM
pjb's Avatar
pjb
pressurize cooling system and look for bubbles in the PS resevoir.
Old Sep 9, 2008 | 09:47 PM
MisfitJ03's Avatar
yea theres a very small PS leak, i may only have to add 1/3" of fluid every 2 weeks or so, so thats probably not it
Old Sep 10, 2008 | 11:07 PM
wssix99's Avatar
Save the manuals!
What does your coolant dipstick look like? Is it clean? If so - its probably not it. 1/3" every 2 weeks sounds like a pretty fast leak to me. (Unless you have visable leakage at the external hoses.)
Old Sep 22, 2008 | 09:14 PM
MisfitJ03's Avatar
well now im pretty much 100% sure my PS cooler is leaking. the other day i was driving the car and my power steering suddenly went out. pulled over and checked it and found that it was almost empty, then i checked the coolant and it looked brown. sound like the PS cooler to you guys?
Old Sep 22, 2008 | 09:23 PM
wssix99's Avatar
Save the manuals!
What does your coolant reservoir dipstick look like? Other contamination can make it brown, but the slime on the dipstick is pretty distinctive.
Old Sep 22, 2008 | 09:37 PM
TopFlite's Avatar
Just how exactly does power steering fluid arrive into the coolant system??
Old Sep 22, 2008 | 10:22 PM
samson_420's Avatar
Through the leaky cooler in the radiator.
Old Sep 23, 2008 | 05:49 AM
pjb's Avatar
pjb
the cooler is not in the radiator, its in the upper hose/pipe.
the quick easy test is to get a free loaner radiator pressure tester from autozone, pressurize the cooling system and look for bubbles in the PS resevoir. it will be obvious. replace the cooler pipe and flush PS and cooling systems.
Old Sep 24, 2008 | 03:02 AM
TopFlite's Avatar
Wow, that's quite a system destined to cause trouble. Noticed some buildup on the slotted opening's along the middle of the coolant dipstick after reading this thread and to top it off, my power steering cap is leaking. Hope some of the missing power steering fluid didn't end up in the coolant.
Old Sep 24, 2008 | 11:11 PM
MisfitJ03's Avatar
yea it was definetly the PS cooler, and yea the dipstick for the coolant was quite slimey lookin. so today i just bypassed the PS cooler and then flushed the PS and cooling system until the fluids looked good. is that PS cooler really necessary or should i be ok with it bypassed?
Old Sep 25, 2008 | 12:20 PM
pjb's Avatar
pjb
my PS cooler leaked into the cooling system and caused the same problem you originally posted about - false coolant low light. replaced the cooler, flushed PS and coolant, cleaned coolant level sensor - no more problems.
Old Sep 25, 2008 | 12:22 PM
pjb's Avatar
pjb
I like all my stuff working - nothing rigged. why not just replace the cooler/pipe?
Old Sep 25, 2008 | 02:37 PM
Grimes's Avatar
you will be okay with it bypassed. but you'll have to plug the lines at the bottom of the cooler otherwise coolant will drip out (because of the hole in it). I installed a air/liquid cooler for my ps fluid because i thought that I would do some autoX in the future.
