firebird headlight lid probablem
...... is there maby a switch that went bad or are they electronicaly timed..... pleas if any one has had this probablem or has any idea what it is let me know...feel free to contact me direct
cudaeh@yahoo.com
I was having that prob earlier this year... also w/mine if I hit the lock or unlock buttons on the key fob it would cause the headlights to pop up and go back down followed by a strange noise...
I messed up flipping my gear (you only hve to take the lower section apart, don't take the top medal cylinder off) so I had to put a new motor in
Now, I plan on opening it up and turning the gear so that the worn spot is in the 180 degrees or rotation that is not used ... if possible.....
Gordon
www.provenperformanceconcepts.com
just my thaughts though
good luck
REASON for it wearing out? lack of lube on the linkage... opening headlights at 90mph... aging plastic... cracked support tabs/screw mounts....
over 5 front end electrical problems in ONE week -- due to summer storage in heat and driving through a huge Florida rainstorm. 2 front turn signal bulbs popped (water in housing and dried up dielectric grease), headlight motor gear, headlight socket fried, same headlight bulb fried, fog lamp - melted with high watt bulb/ popped bulb/fused unit in socket.
cost: 10 headlight, 10 headlight socket/rtv, 5 turn bulbs, 75 glass lens fog light w/55 watt bulb, headlight motor - free/grease
dealer estimate; $400 for turn signal problem. $400 for headlight motor, $200 replacement plastic lens fog light, $125 headlight socket.
INTERESTING: all of these items appeared 2 months AFTER the warranty ran out and one month after the dealer changed the oils and recommended a list of other bogus things done that I turned down. Does anyone here think the dealer mechanics would spray my connectors with degreaser and then saltwater? Hmmmm.... It's not going back for FREE oil changes anymore.
