Super Victor
Old Oct 12, 2008 | 11:17 AM
Cruz Lo's Avatar
Default Super Victor
I want to retrofit one to my truck motor.
I have the elbow all figured out. But....
What fuel rails do you use? Edelbrock set?
What injectors will I need? Can I use the Truck injectors?
What fuel regulator does everyone use? The ones I see are red but no name?
Also they don't seem to be vacuum?
Thanks for the input.
Old Oct 12, 2008 | 04:32 PM
Cruz Lo's Avatar
Bump.
For a poor guy looking to tech help!
Old Oct 13, 2008 | 08:10 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
What other mods are done to the engine? The Super Victor would be over kill for a most H/C setups.
Old Oct 13, 2008 | 09:41 AM
Sammyboy's Avatar
Speed inc sells a fuel rail instillation kit...#RGR501 which you find to come in handy when using those edelbrock fuel rails.
Old Oct 13, 2008 | 09:47 AM
BIG_MIKE2005's Avatar
If you buy the Edlebrock rails from Summit it comes with the rail install kit. Not the braided hoses but the rails mounts you need.
You can also use any set of aftermarket rails & injectors but you will have to make your own pieces to hold the rails in tight on the intake. Which shouldn't be hard to do with some scrap metal & drill.
On the FPR look at getting this one. It's Aeromotive & is what you'll need. Nicely priced also. It's the one I"m goin with.
Summit part #: AEI-13105
Jeg's part #: 027-13105
Old Oct 13, 2008 | 07:56 PM
Cruz Lo's Avatar
Thank you for the replies.
Good info.
I expect that the super victor is overkill and for a mid cammed 5.3 and not the best performance solution, but it looks a whole lot better than the truck intake! And will fit with the right elbow and by acc setup.
And will hold the future mods to come.
Thanks again.
Old Oct 14, 2008 | 06:51 PM
a98ws6's Avatar
Will a Super Victor fit under that hood? Its pretty tall
Old Oct 14, 2008 | 08:47 PM
LS1-NAVY's Avatar
damn nice truck man
Old Oct 15, 2008 | 03:04 AM
azceta's Avatar
+1 Looks sweet as hell. good luck
