Header Install Check List.
Old Oct 14, 2008 | 12:26 AM
slikrider20's Avatar
Default Header Install Check List.
I've done a little searchin, but i haven't done a header install before and want to get a to get list before i do anything. I'll be putting on some pacesetter LT's/ory
Basically i just want to know all the mandatory parts. I'm debating on whether buying them new from texas speed (520 shipped) or just going with a used set.
If i were to purchase them new, would all i need be the 24'' o2 extensions? I would assume all the bolts/gaskets would come with the headers. Someone help point me in the right direction, and thanks for the time
From what i understand, the gaskets they might come with are junk and i should get some GM ones, best place to purchase these?
Old Oct 14, 2008 | 01:02 AM
Ehatcher's Avatar
Headers- Check
extensions or vette rear 02's - Check
Do not use paper gaskets supplied with Pacesetters-Check
Reuse or buy new OEM gaskets- Check
02 sims or tuning software to turn off rear banks-check
Ability to get the car pretty damn high off the ground- Check
Ratchet wrenches- Check
patience- check
Beer-optional
Old Oct 14, 2008 | 01:48 AM
Vndcatr's Avatar
Beer and Pizza a must !.. but yea Pacesetter includes it all . but yea like Ehatcher said either stock GM gaskets or FEL-PRO's ..
While your in there , replace your plugs/wires . Its so simple
If you need any block off plates, buy them and gaskets for those..
Patience ! the outcome will be worth it
Old Oct 14, 2008 | 02:23 AM
slowformula's Avatar
Originally Posted by Ehatcher
Headers- Check
patience- check
Beer-optional
Go directly off of this. Except make beer mandatory, rather than optional
Old Oct 14, 2008 | 07:40 AM
Thanks guys, that makes it easy. Does gm parts direct have the gm gaskets?
Old Oct 14, 2008 | 07:51 AM
lastcall190's Avatar
PM or contact SDPC. They have great prices, fast shipping, and prompt customer service. That's where I got mine from. "Scoggin Dickey" is a username on here.
-J
Old Oct 14, 2008 | 10:54 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
We keep the gaskets here. You could also reuse your stockers in most applications. We have any parts you could need, even headers if you don't already have a source for those. I saw you mentioned TSP up there, if you plan to get the headers from them they can also get you anything else you would need.
You don't have to know what you need, just give them or us a call and we'll get you where you need to be
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Oct 14, 2008 | 10:58 AM
Sammyboy's Avatar
Go with QTP....they come with metal gaskets and some nice merge collectors.
Old Oct 14, 2008 | 11:36 AM
Pushead's Avatar
Having two jacks, a bunch of 4x4s (or anything beafy enough to keep the front end of the car up that high), and having two other friends to help out made the swap extremely easy.
Old Oct 14, 2008 | 06:49 PM
Sounds awesome, i'll be in touch with you guys.
As far as the QTP headers, i want to keep it around 550 shipped or less, i don't want to shell out a fortune. I don't even know what those cost though.
Old Oct 14, 2008 | 07:36 PM
extinctls1's Avatar
Do a poly motor mount set swap out while you are doing the header install. This will save you a ton of *** pain down the road if your Y-pipe is banging. get the longer 02 extensions they aren't that much more and you can just zip tie the slack. I got all of my hardware (extensions, rear 02 sims, header gaskets,MSD wires, spark plugs) from www.speedinc.com they have everything and free shipping. Free shipping on headers also which saves alot of money good luck bro !
Old Oct 14, 2008 | 07:59 PM
So i will also need rear o2 sims?
Which size would you reccomend for the extensions?
Old Oct 14, 2008 | 08:01 PM
IMO skip the 02 sims, and have a shop tune out the rear 02 sensors. Extensions you can get away with a 12" and 24", although 2 24" seems to be the norm.
-J
Old Oct 14, 2008 | 08:06 PM
I was gonna say 100$ to keep a light off....i don't think so. So 2 24" runs of o2 extensions will do.
Old Oct 14, 2008 | 08:12 PM
Yep, done it like that with every header install I've done. Even the ARHs I got they sent me two 24". You will have extra wiring to bundle up, nothing a few zip ties can't fix.
-J
Old Oct 14, 2008 | 08:14 PM
Awesome, i think i know everything i need now. It was mentioned above i could use the stock gaskets. I'd like to save money if possible, is it worth to spend the extra 40$ for new gaskets? I'm on a pretty tight budget
Old Oct 14, 2008 | 08:27 PM
IMO I would. If I recall correctly it was ~30 or so for new ones from SDPC. I only figured, well, I'd hate to have everything back together only to find out one of the gaskets **** the bed, and have to pull it apart. That's just me though. I hear you on the budget thing though.
-J
Old Oct 15, 2008 | 11:44 PM
Red96TA's Avatar
If you get pacesetters dont use their bolts. The ones I got were all too long! PITA
Old Oct 16, 2008 | 09:56 PM
Ehatcher's Avatar
I reused the stock bolts. They all looked like they were in great shape. If you have any doubts about the stock gaskets, go ahead and buy some new ones. It will save you some grief. I still have my stock gaskets with my headers. I installed the headers at 79,000 miles and over 30,000 miles later I have zero problems.
