Exhaust Pics?..I just cant decide... HELP!!
Okay im going to be looking for Exhaust soon for the camaro. My boyfriend told me that I needed to go on here and start looking at all the different setups that are avaliable. I tried to do a search and only found like a few. Im new to the search thing so please help me out and post up pics of your exhaust setups. I would really like to see what they lok like in coming out the back too. Thanks
are you looking for just a cat back? if so, i would look into magnaflow, slp loudmouth (sounds great on stock mafifolds), or borlamouth.
theres tons of info on exhaust here and im sure you will be able to find what you want
i went with hedman headers lt, with dual exhaust feeding 2 10 series flowmasters, wit no cats all the way out the back and i luv the sound at wot. it also scares da crap out of these ricers.
But thank you to the ones that have added to this thread. Keep them coming!!
i went with 3"...but you may want to stick with 2.5"
if you REALLY want tips...check out the true duals stickies...there are some good pictures of duals over the axle side by side.
go on summit racing and you can buy 2 sets of I-pipes for a v6 fbody that are 2.5". take a regular LT header Ypipe, cut the merge off, build it into a side by side Xpipe that magnaflow makes, then connect the I-pipes.
once over the axle...add some magnaflow 4x9 mufflers and tips.
that's my suggestion
Here's vid of mine, the pics post is in there as well.
https://ls1tech.com/forums/showthrea...613&highlight=
Everyone here says custom, custom, custom. There are other options besides custom if you don't have a exhaust shop around. Nothing about my exhaust is custom and it flows, fits, and looks pretty righteous.
