Dropped my new forged piston
Hey guys im here to ask if i can still use my piston that fell of my table onto a concrete floor. It got a flat spot on the crown and nicks on skirts. Thank you guys.
Probably okay to use, I would say. If there's a ridge burr, just hit it with a file to knock it off
Blend it all out and it will be fine. Make sure the rings are totally free.
The following users liked this post:
strutaeng (06-05-2024)
And JE sells singles all of the time, unless it's a custom part. If Texas Speed won't do it for you, I will ... but you don't need one.
If you do decide to go that way ... make certain you getting one that matches your weight. They vary significantly even within a singe run.
G Atsma (06-05-2024)
I checked with JE. That Job Number is a proprietary part number that they make only for Texas Speed, so Texas Speed should be able to sell you a single, but JE has nothing to do with it.
The following 3 users liked this post by AlexG03:
Forget about it!
Gtg!!!
Send. It.
