Coolant leaking while TB off???
Old Oct 29, 2008 | 10:11 AM
Paul 1953's Avatar
Default Coolant leaking while TB off???
I've sent my TB cross country to be CNC ported. While it's away, I've got the car on stands to do the headers & poly mounts. The whole time I'm crawling around, there is a steady slow, drip....drip....drip of coolant that wasn't there before.
When I removed the coolant lines from the TB, of course, I got a gush of coolant out. I thought that this was maybe the left over drips. But no, it's still coming. It's NOT from the tb hoses. It's somewhere on the front driver's side behind the pulleys, but I can't see.
If anyone had this or has any ideas, thanks. Just seems a funny timing coincidence that I just opened the coolant lines at the TB, and got that initial gusher.
Maybe my car doesn't like being so high up off the ground...lol
Old Oct 29, 2008 | 10:20 AM
Damian's Avatar
LSX Mechanic
It's probably where the coolant puddled when you pulled the TB.
Turn the paranoia meter off man, you're good
Old Oct 29, 2008 | 10:46 AM
Raise's Avatar
You're ok man...no worries. If its dripping out of the hoses, just position them so they are angled upwards.
Old Oct 29, 2008 | 11:57 AM
TheBlueKnight's Avatar
yea, I didn't angle the hoses up while mine was being ported and a bit of coolant was leakin all over my pulleys, I just angled it up and it stopped. BTW, with my new slp lid and ported TB, my car hauls in second and third!
Old Oct 29, 2008 | 01:32 PM
zachness's Avatar
gm uses uses coolant to heat up the TB so that in the winter in northern sates the throttle plate doesnt stick. It heats up the oncoming air so do a throttle body bypass while you get it ported. just buy a 3/18 copper pipe (i think that is the correct size) and connect the hoses and zip tie them on both ends. Its held for me almost a year and it should for you aswell.
If you live up north though i would recomend you keep it as is. I live in texas so i get to bypass it.
Old Oct 29, 2008 | 02:04 PM
Sammyboy's Avatar
yea...it isn't a big deal...just bypass the TB as long as you arn't in too cold wheather conditions
Old Oct 29, 2008 | 07:19 PM
I live in a cold climate and did the bypass, snows here quiet often, I've never had a problem with my TB sticking.
Old Oct 29, 2008 | 08:04 PM
Haans249's Avatar
Pop your radiator cap, as you might still have some pressurization in the system pushing the coolant out.
Old Oct 29, 2008 | 10:39 PM
Paul 1953's Avatar
Thanks guys for the tips. Maybe I am just being "paranoid". But, like I said, the TB hoses are pointed up, dry and NOT the source of the leak...(coolant slow, steady dripping 3 days after the TB disconnect.)
Old Oct 29, 2008 | 11:01 PM
Damian's Avatar
LSX Mechanic
You would be amazed what fluids will puddle down in your K-member (frame the engine sits on). I've seen 2+ qts of power steering fluid lurking in one before from a customers car that had a leaking PS hose. Even after replacing the hose the car still leaked PS fluid for a month
