Difficulty of removing engine...
Also any special tools i might need? and how much harder is putting it back in without the lift?
Is it my best bet to just do it at school anyways?
It is obviously easier on a lift, and if you're careful to not move the K-member at all you can usually get away with not having to align the car again.. just lower the lift back down exactly how it was.
What are you wanting to do to the engine?
I'd recommend one of these to roll the k-member/motor on and have a floor jack supporting the trans.
Works like a champ.. and when your body is sitting on jack stands you can jack this thing up and line up your k-member bolts.
Is there any Clearance issues with removing from the top?
also, getting the bolt into the back of the head sounds like its going to be a bitch since thats back under the cowl. wouldnt this cause clearance problems since the cowl is covering the back of the engine? Im thinking once you have the chain connected and start to pull up its going hit the bottom of the cowl and cause some major problems.
