question on a setup from LSX shootout.
Old Oct 31, 2008 | 06:23 AM
Nimitz87's Avatar
Default question on a setup from LSX shootout.
this photo...
thats a GMPP intake to a 4150, with a nitrous pro-flow diffuser plate correct?
how do you filter that setup
what are the pros of a plate setup like that compared to a 92 FAST with 2 stage plate?
looking at iron block 408, solid roller + 2 stages of 150 shot.
would the GMPP be a good fit? or go the more traditional route?
Chad
Old Oct 31, 2008 | 08:41 AM
ATVracr's Avatar
That is the new Intake from Cary @ Performance induction solutions (he also works for ETP)
Difuser is a Speedtech brand name, Wilson makes the Nitrous Pro Flow plate.
Looks to be a 4150 flanged intake with a 4500 throttle body on top.
That Intake and TB combo probably makes close to 100 more HP than a FAST would with his set up.
Old Oct 31, 2008 | 02:46 PM
Nimitz87's Avatar
thanks!
for street use how would you use an air filter?
wow that's a huge difference. so for 2 stage setup with the single plane intake, and 4150 what's the best route? direct port, plate, spray bar?
I know that's an open ended question, and probably should be in the Nitrous forum. but basically I want to beable to run either all motor, 1 stage, or throw down and run both stages. fuel system will be a stand alone for the nitrous.
Chad
Old Nov 9, 2008 | 01:16 AM
THROTTLEJUNKIES's Avatar
Bump on this one.....wondering the same thing for my setup.
