No Oil Pressure..
Old Nov 5, 2008 | 12:20 PM
onebadredss's Avatar
Default No Oil Pressure..
Friend bought a running 2000 Z28...
But the Oil Pressure gauge isn't doing anything... what do you all think is wrong... it has a 6.0 block and other stuff...
Old Nov 5, 2008 | 12:22 PM
sdavis2702's Avatar
Oil pressure sensor probably broken. It's located behind the intake manifold. Shouldn't cost more than 40 bucks. Usually breaks when somebody removes the intake because a hose connected to the back of the intake wraps behing the oil pressure sensor and it can snap pretty easy.
My thread from some time ago may help a little.
https://ls1tech.com/forums/showthrea...t=#post7261208
Old Nov 5, 2008 | 12:24 PM
ya i checked to see if it was snapped it ain't...
Old Nov 5, 2008 | 12:25 PM
sdavis2702's Avatar
Hmmm... my bad maybe I am off then. Hopefully someone chimes in that knows more than me lol. Good luck.
Old Nov 5, 2008 | 12:27 PM
GM WORLD CLASS's Avatar
Unplug it. Key on engine off should go extreme hi or lo. Or hook up a test light between both terminals on connector. If light illuminates and gage move like it should then replace sensor.
Old Nov 5, 2008 | 01:11 PM
Sammyboy's Avatar
yea....I broke mine....and my oil pressure shot all the way to the other side.....
Old Nov 5, 2008 | 02:34 PM
I have never heard of doing this... so you just unplug the OPS and it should move on the dash...
Old Nov 9, 2008 | 09:05 PM
jugz ss's Avatar
i broke mine and replaced it and the oil pressure gauge doesnt move at all
