New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
#142
Damn that looks interesting
Need to check:
--fit under F-body hood & cowl
--[b]throttle body compatibility (3 bolt or 4 bolt or both)[/img]
--stock throttle cable fit
I don't think stock fuel rails will work, but I don't see why you couldn't use what ever fuel aftermarket rails you currently have, you might need to change the cross over though.
Need to check:
From the pics you can see its a 3 or 4 bolt! TB You can se that they have a 3 bolt TB on it and you can see the hol for a 4 bolt TB
![](http://i69.photobucket.com/albums/i80/Dansredz28/IMG_0566.jpg)
![](http://i69.photobucket.com/albums/i80/Dansredz28/IMG_0567.jpg)
#146
#147
They said it should be out in January 09. I think I am going to by into this intake. They said it will fit under a 04-06 GTO hood. I have a ported 90 MM throttle body so I am not sure it will accept my TB.
OK, where are all the naysayers who are going to start bitching about
HEAT SOAK
HEAT SOAK
#153
Do some more research 1st! you will see that if you run that intake with the elbow with hurt the performance and its best if you ad a 2000cfb TB on top of it and you will gain a good 20-30whp. I was going to do the vic with elbow until i saw how much the elbow was choking down the motors
#156
I think it will work well with my cam. I really don't care about any HP gain. I am very happy where I am at right now. Doing it for the looks . It looks wicked under the hood
#158
A daily driven car will see some heat soak with any alum intake that is fact, thing people don't understand is how little it matters.
Everyone thinks that becuause a car with a roots blower loses 50 hp from heatsoak that anything with an alum intake is gonna have the same problem. You will have some heat soak, to the point that a degree of timing, probably ONE degree will have to be pulled due to the intake charge being a touch higher, whoopie.
I do wonder why something like that hasn't been made from fiber reinforced delrin, a simple mold with a machining finish process could be done that would result in the same thing that wouldn't have the issues, and the cost would be a ton less... why noone has gone down that path I don't know.
