Headers came in.. take a look
Old Nov 13, 2008 | 10:40 PM
Detoxx03's Avatar
What kind are they?
Old Nov 13, 2008 | 10:47 PM
rice4eatingnotdrivin's Avatar
on the drivers side header, the O2 bung is facing towards the outside of the car... the only problem with that is there might not be enough clearance.... atleast with my headers i had a clearance problem... i couldnt even get the O2 in
Old Nov 14, 2008 | 07:02 AM
Weezzer's Avatar
Originally Posted by ophee
...Should i be sending these back or what?!?!?! Or is it ok.
Only way to tell fer sure is to try and mount them, you won't know till then if they are gonna give ya trouble.
Old Mar 20, 2009 | 11:50 AM
ophee's Avatar
I'm bringing this back...
I had the headers installed.. sounds like garbage, whenever i steer left or right (sometimes without steering), i hear this terrible noise. I think it's all slamming into the cross-member. Also, whenever i accelerate i hear AIR out of the left side of the car...
I was told to cutoff the AIR/EGR connections and have the holes welded shut, but never did this. Could this be why?
Old Mar 20, 2009 | 12:52 PM
BAD2000TA's Avatar
Did you re-attach the EGR and AIR tubes? Or, did you get some block off plates? If you didn't do either one of the two, there's your "air leak".
As for the noise, you're probably rubbing on the crossmember or steering column. The fitment of these headers is hit or miss. Basically - you get what you pay for. Take a look underneath and see where it's hitting. Try to grind down those areas for some clearance. Remember, once the engine has a load on it, it'll torque over more than what you are seeing just sitting there at idle.
Good luck....
Old Mar 20, 2009 | 12:54 PM
BAD2000TA's Avatar
FYI - I notice you have an '02. You won't have an EGR tube, so you need to block that tube on the header. It'll be on the passenger bank if they are equipped for EGR.
Old May 4, 2009 | 04:34 AM
ophee's Avatar
I took the car back to the mechanic, told him about the air sound. He said it was normal. I don't believe him. So what i tell'm is that he needs to block off (as in weld, or block off plates as i hear?) the EGR tube on the headers? The headers are already on, can he do them with them on? Thanks folks
Old May 4, 2009 | 11:35 PM
Mumbles's Avatar
Hello again ophee...
I checked out the pictures in your original post. I see the passenger side header has the EGR fitting. So, yes. You need to have that port blocked with a block-off plate. Or you can cut the fitting off the header and have the hole welded shut. If it is left open, that is definetely where you're getting your "airy" sound. Also, if that wasn't noticed by the grease monkey who installed them, its time to find a new mechanic. That's grade school ****.
In a later post, you stated that you're hearing a "slamming sound" when you turn left or right. Did the headers come with a Y-pipe? Or maybe your wonderful technician fabricated one for you. Either way, this slamming could be the collectors or Y-pipe banging on the floor pan or K-member from the torque of the engine or flex when you turn. You could need to upgrade your motor mounts to Polys (or solid), to eliminate this. I installed these on my car at the same time I did my headers. Having the exhaust outta the way makes installing motor mounts on these cars 100 times easier.
One more option is to start again from scratch. Get yourself some expensive stainless steel American Racing Headers with a Catted or Off Road Y-pipe. Then you would be certain you are getting a quality product. While installing the new headers you could upgrade your motor mounts. You'd have to write off the cost of the ebay headers all the other hardware you have invested should interchange with any new setup. Take it as a learning experience and move forward. Just a suggestion.
I don't know man...Whatever you decide... Good luck!
Old May 5, 2009 | 10:27 AM
colby72olds's Avatar
So are they ebay headers? I see where Mumbles says so, but I never read where you said they are... so I'm sonfused haha. I'm pretty sure Speed Inc and Texas Speed both sell the block off plates. Also, are you sure it's not just your Y-pipe banging, instead of the headers? That's what mine does.
Old May 5, 2009 | 10:58 AM
smok'nZ's Avatar
MASS seller approved
the tubes look weird to me i guess bc i have and old set of grott's
Old May 5, 2009 | 11:31 AM
LS1nterceptor's Avatar
On the headers there are metal pipes coming off the headers. They are open ended and have to be blocked off. Below is a picture of a block off plate set. The 3 pictured on the left are what I'm talking about. These need to go over the open ends. That is probably where the air sound is coming from.
Old May 5, 2009 | 11:46 AM
  #32
383lt1impala's Avatar
I have a set of those I got them for 185shipped. For my impala swap didn't want to get a more expensive set since I have to bang the drivers side and reroute a primary.
Old May 5, 2009 | 12:14 PM
  #33
05 GSXR 1XXX's Avatar
Yea that driver side looks like they werent payin attention when they welded on the collector..
i also see that there are like 10 bolt holes, did they say it was universal of somthing??
not sure but it looks like the passenger side has a pipe that could have been routed another way may just be me i havent looked at f-body headers in a while..
Did you get that air sound gone? maybe loose clamp or header bolt not tq down enough?
a while back i bought long tubes for my C5 and they turned out like ****, the x pipe they sent didnt even match up and had to have a shop modify them pretty bad.
hope things turn out ok for ya bud!
Old May 5, 2009 | 05:15 PM
  #34
Mumbles's Avatar
i ended up buying 02 extensions, stage 8 bolts, new GM gaskets, prothane motor and tranny mount. wires/plugs, flowmaster merge collector, two dmh cutouts... there could be more. I hate LS1's... I was never this trigger-happy with buying parts with any other car!
I was reading through the entire thread again and noticed the list of accessories that you invested in. (Guess I missed it the first ten times I read it. *duh*) Did the mechanic install the motor mounts when he did the header install? If so, the banging probably isn't your Y-pipe hitting. Maybe you'll have to notch the K-member as Intercooler2 suggested. My header install wasn't this much trouble, but I took my time and did it myself. So I'm not really sure what else to suggest.
