intake install ?
Old Nov 22, 2008 | 10:21 AM
firehawk#682's Avatar
Originally Posted by conan
this is a very helpful site. I just followed this and it went very smoothly didn't break anthing.
Old Nov 28, 2008 | 05:27 PM
CoastieWS6's Avatar
Originally Posted by Pntbll309
Like said above, be careful of the oil pressure sending unit. I did my ls1 to ls6 swap in under 2 hours by myself. Clothes pins work great for the last few bolts.
+1 on that. The clothes pins work great. Also have someone help you when you pull the inake off. I was hold the back of the intake up, to keep it from breaking the oil sending unit and my friend pulled it forward. I didn't break mine
Old Nov 29, 2008 | 09:21 PM
6']['9's Avatar
the LS1how to site says you have to grind that piece underneath the valley cover, does this need to be done or not.
Old Nov 29, 2008 | 10:17 PM
4150's Avatar
Be carefull of your injector o-rings as well, mine were hard as a rock and split even though they were lubed when I went to install the injectors.
When I went on a hunt to replace them on a Saturday morning Autozone didn't have them listed and those that did have them listed didn't have them in stock, after doing a bit of part number cross referencing it turns out a '92 Jeep Cherokee with an I6 uses the same o-rings and happened to be in stock at Autozone for $8 for a pack of 12. Just keep this in mind if yours are as screwed as mine were, it's also not a bad idea since you have it apart anyway.
Old Nov 29, 2008 | 10:18 PM
lgracer's Avatar
Default grindin
I have a 98 ls1 and when you put an ls6 intake on it you either have to block off the rear steam/coolant crossover tube or do it like its done on ls1howto. I just ground down the ribs on the bottom of the intake. I didnt want to spend the extra cash on the tubes from the later model crossover tubes.
Old Nov 30, 2008 | 04:47 AM
lovin myls1's Avatar
+1 on grinding or tubes. I think someone said to put some grease or vasoline on the tube, then set intake down on that, then pull it away and you will see where to grind.
