installation of 160 degree thermostat
thanks alot
http://www.installuniversity.com/ins...ostat_swap.htm
Al
WRONG...well...partially wrong.
any time the car is moving and passing air over the radiator you will benefit from the stat regardless of what your fan settings are.
only time the fan settings come into play is when the car is sitting still in traffic or staging lanes. and usually a fan switch is cheaper than a tune.
i ran a lower stat for 6 yrs with stock fan settings and could see the cooler engine temps any time i was driving. it even took a minute or 2 of stopping for the temps to climp up to where the stock stat would have started.
fan setting changes to see any benefit is a big misconception
A fan setting change is needed to lower temps for city driving.
I had heard somewhere that around 25 mph the forced airflow over the radiator is more than a fan will pull...varies a bit with each fans cfm. Can anyone confirm that mph???
I couldn't agree more with this post
I actually want my temps to get up there to vaporize the water and acids out of my oil that are a byproduct of combustion. That is why I switch to a 185* in the winter......to make sure it runs hot enough. I installed a big Howe Racing radiator and switched to a 160*stat in the summer because I was seeing 230* temps in our hota$$ summers driving around town with the A/C on.....
