Will Granatelli LS1 MAF fit a 2002 Silverado 5.3??
As title says I have an LS1 Granatelli MAF and I was wondering if it will fit a 2002 5.3 truck? I know factory MAF's I think are the same as the truck,
Re: Will Granatelli LS1 MAF fit a 2002 Silverado 5.3??
i probably would
if you already have it try it
if it runs rough or sets a ses light
you mite try a resister on the two long
sensor post on the bottom
i would try a 500 - 1000 ohms resister
just try out diffirent resisters or even a reostat
solder two wires on the post and run it between
the maf ends to the out side where you can reach it eazy
and put your resister there so you dont break the tiny wires
trying to change the resister
hope that helps
worked on my 99 v6 camaro when i put a maf from a blazer on it, worked better
hope that helps
