CFM Ratings from MAF to Intake Manifold
Old Sep 23, 2003 | 11:40 PM
Brody's Avatar
Default CFM Ratings from MAF to Intake Manifold
Ignoring filter and heads, what is the CFM rating of everything between them? (MAF, Air Bridge, Coupler, Throttle Body, and Intake Manifold)
I'd love to hear results from C5 of F-Body, but specify what you're talking about. (eg LS1 vs LS6 manifold)
Old Sep 24, 2003 | 08:51 AM
BAD XXX's Avatar
Default Re: CFM Ratings from MAF to Intake Manifold
I believe it's 780 cfm.
Old Sep 29, 2003 | 11:33 PM
Brody's Avatar
What is 780 cfm? Break it down by part if possible.
Old Sep 30, 2003 | 01:47 AM
blk~2000~Z28's Avatar
It seems pointless to do this since they will never each be used without the others.
Old Sep 30, 2003 | 11:11 PM
Brody's Avatar
It sure would be nice to know where the bottlenecks are, and at what points the other components become one. It's NOT pointless to better understand our cars.
Old Oct 1, 2003 | 03:01 PM
Cal's Avatar
Cal
The bottle neck is the throttle body and the throttle body opening in the intake manifold. Actual cfm depends on the presure differential you are measuring it at, but I think it's around 800 cfm using the normal standard. Replacing the TB with a bigger one is easy; the problem is you can't port the intake manifold because the plastic is thin and oddly shaped. The new LSX intake manifold may give us some relief, but at a hefty price.
Old Oct 5, 2003 | 05:09 PM
Brody's Avatar
Thanks Cal! Do you happen to know what CFM F-Body and C5/Z06 intakes flow? What about a Donaldson blackwing?
I know I didn't ask about those things initially.
Old Oct 5, 2003 | 05:37 PM
Z-Rated's Avatar
they are the same, but the LS6 flows more. The LS6 comes on cars 2001 and up. BTW it doesnt matter if its a C5, ZO6 or an F-body as long as its an 01 or newer
