Whine with the Defroster on?
It is normal to an point.
You don't have any reason to think the alternator is getting weak do ya?
I don't have any reason to suspect the alternator is going bad (but I'm far from an expert.) I had a battery replaced under warranty about a year ago (car wouldn't start) but I've had no problems ever since. The only reason I bring this up though is because I never really noticed the noise before. So everyone else's alternator kicks in at that point also? before it heats. Do you hear the same sound if
you run A/C instead of defrost?
Try it with the A/C on open the hood & rev the motor & see if thats your noise w/ A/C on & off.
Seen plenty of A/C compressors go south & make noise.
