Which LUBE for ASP Pulley?
The instructions for the ASP Pully say to lubricate the snout when installing. What type of lubricant should be used?
Also which thread locker should be used the RED, or Blue?
Thanks,
Thanks,
Re: Which LUBE for ASP Pulley?
Pretty much any greese will do for the lube. We just use a bearing greese here. You should NOT need any kind of thread locker at all. You have to use a new bolt when installing the pulley and it already has a thread lock on it. Hope this helps...
