ported LS6 gains?
Old Dec 22, 2008 | 01:11 AM
JRC2000SS's Avatar
Default ported LS6 gains?
i've been thinkin of porting my LS6 intake but i've not seen very many post on the gains. if there is any one out there who has done this please give me your input. whats gains if any did you see? if you had to go back would you have bought a FAST 90 or 92?
Old Dec 22, 2008 | 05:07 AM
DiabloFormula's Avatar
You can't really port the LS6 intake.......but one thing i did do with mine was open up the snout a good bit, if you run your finger down the snout of the intake you will feel a ridge. What I did was sand the material down to those ridges, I'm sure it helped a little but no before or after dynos or anything like that.
Old Dec 22, 2008 | 07:39 AM
smok'nZ's Avatar
MASS seller approved
im sure ls2portworks gets 5-10 rwhp i know they port them tho
Old Dec 22, 2008 | 10:49 AM
golfinz's Avatar
I talked to LS2portworks about porting mine and Corey said there is no measurable gain in doing so, about 5rwhp. That small of a gain could be contributed to other factors. Im saving my pennies for a FAST setup, even though I think the price of them is ridiculous.
Old Dec 22, 2008 | 10:58 AM
deuce_454's Avatar
TPIS can do a 90 mm TB conversion that will add 15-20 Hp and outperform the fast below 6000--- but fall on its face at 6500 compared to the fast
Old Dec 22, 2008 | 02:04 PM
JRC2000SS's Avatar
cool fellas! thanks for the info. now i guess i'll be saving up for a FAST 92. It's just so much money to spend and by all means i'm not trying to sound cheap either.
Old Dec 22, 2008 | 02:54 PM
LS1-450's Avatar
These threads always end up w/ is FAST better or is LS6 better. The answer is neither. We need your mod list including how high you spin the engine. Generally, up to 6300 RPM, a 90mm LS6 is the best for stock cubes with mild to slightly agressive cams. If spinning up to 7000 RPM, big cam, &/or larger than stock cubes, then generally, FAST is the better choice.
So, what sre your specs?
Debating between FAST & LS6 is like arguing about whether or not Blondes or Brunettes are better. You can't lose w/ either, but one or the other is a better fit for your engine.
Old Dec 22, 2008 | 03:01 PM
Mike454SS's Avatar
You can DEFINITELY lose with Blondes AND Brunettes
Old Dec 22, 2008 | 03:07 PM
03Sssnake's Avatar
quoted for TRUTH!!
Old Dec 22, 2008 | 03:18 PM
JRC2000SS's Avatar
current setup is 2.5 prc heads with a torquer 3. its still a stock bottom end motor.
Old Dec 22, 2008 | 04:39 PM
LS1-450's Avatar
Even if you had those + long tubes, I'd say 90mm LS6. Unless you're gonna spin that stock bottom end to 7K...yikes!
I have tested through tuning software, a modified Ls6 intake that is similar to a 90mm LS6 against a ported aluminum Weiand (thread can be found in a "search," I miss-spelled Weiand, so I think it's titled "Ls6 vs ported Weand"). Anyway, the LS6produced 8% then 4% higher airflow through the RPM range, as measured through the MAF. Again, this test was done on my engine, mods in sig, but, shows a good improvement over a ported 85mm Weiand. So, I'd say it's a good bet that the 90mm Ls6 would produce even better airflow against a stock LS6.
