Speed Density??
Old Dec 25, 2008 | 01:57 PM
nemss1's Avatar
Originally Posted by Nitroused383
Really a good speed density tune is not going to change much from day to day. Some of you guys act like it would be the end of the world if your temperature or elevation changed. I guess a lot of you forgot millions of people drove carburetored engines and never once changed the jets while traveling.
The only real time I would see the need to change your tune is when they add 10% ethanol into the fuel around winter time. This is only if you desire max performance though.
so what is the deal with SD on an auto? read up that the MAF plays part in the way an auto runs
Old Dec 25, 2008 | 02:32 PM
Nitroused383's Avatar
I really have no idea what role MAF plays with an auto trans. I've only tuned and read about manual cars.
Old Dec 25, 2008 | 05:19 PM
SuperSlow02's Avatar
Originally Posted by nemss1
so how often would u have to re-tune a car on speed density?
like seasonal?
Mines been the same for 2 yrs now, and was only changed in aug. for Nitrous
Old Dec 26, 2008 | 11:49 AM
Z28XTC's Avatar
I think all LSX car's from Australia are SD stock.
Old Dec 26, 2008 | 01:15 PM
kenp's Avatar
The advantage running SD is a vastly improved throttle response off idle and any time you want to goose it a little. The MAF has to "think" about it very briefly and throttle response just isn't as crisp with the MAF. That's my personal experience.
And yes, tuning the VE table takes time. 1 hour wouldn't get it.
If I were tuning for a living I would have the Moats RR to make real time adjustments and then flash the results to the original PCM. That would save a substantial amount of time. Normal method is to drive and log data, use data to recal VE & then reflash PCM. Drive and log data again, rinse & repeat. It does take hours upon hours.
I never had to make any weather/climate change adjustments when running SD. The only reason I went back to the MAF was to prove to myself that I could make it work.
I like SD better & I'm going back to it.
Old Dec 26, 2008 | 04:24 PM
nemss1's Avatar
does anyone make a smooth bellow frm the TB to the intake box?
Old Dec 26, 2008 | 06:09 PM
PowerTalk's Avatar
There was a factory built, 216/220 cammed, Callaway CNC headed LS1 sold new in Australia with SD tune from factory
If your SD tune doesn't make anymore power than a MAF tune, then your SD tune needs more work
Old Dec 26, 2008 | 08:52 PM
Mike454SS's Avatar
I'm curious about this too. I want to get my MAF out of my engine bay. I'll make something if I need to, but I'd prefer a bellows with a bend in it already that I could just connect to the lid and the TB. I guess I'll look around at silicone couplers with bends in them already.
Old Dec 26, 2008 | 09:22 PM
there is a company that makes silicone tubes fo it. I used 4in pipe, bent it, and painted it black...no ones the wiser
