ground clearance on x pipe :(
Old Sep 30, 2003 | 09:24 PM
UGotBeaT's Avatar
Default ground clearance on x pipe :(
Alright well I went to my custom exhaust shop and asked how much a custom 3" x pipe for my 98 trans am would be and they told me 350 with labor so i guess that sounds alright, but they told since my trans am is lowered (eibach springs) that id only have an inch to inch and a half of ground clearance? Does that sound right or is there somethin missin there.....
Old Sep 30, 2003 | 11:29 PM
Z-Rated's Avatar
Default Re: ground clearance on x pipe :(
That does not sound right at all.... Id go check somewhere else too
Old Oct 1, 2003 | 12:16 AM
rspect's Avatar
I am having my exhaust done this Thursday and i am having a 3" x pipe added in also. i am not sure of the exact measurements of the clearance but i've been told that it's not going to be a problem. as far as the price goes my custom shop is going to charge me 200 dollars. to save 150 i would shop around also!
Old Oct 1, 2003 | 05:31 PM
Country Boy's Avatar
Senior Member
If youre lowered, that sounds about right I had to raise mine back to stock with my 3".
Old Oct 1, 2003 | 05:35 PM
chrismcdaniel's Avatar
i have a 3in y pipe off my headers, it my not be a x pipe, but its still 3 inches and i have eibachs, there are no clearence problems unless you have nasty speed bumps
Old Oct 2, 2003 | 07:40 PM
UGotBeaT's Avatar
damn I dont want to put my car back to its stock height, but i want that damn x pipe
rspect - my custom exhaust shop is about the best place around and they are a well respected shop, but they've never done an x pipe on a ls1 before....
Old Oct 2, 2003 | 11:12 PM
A-Bomb's Avatar
i got a 3" X-pipe on my car with 12 " bullets on my car and ground clearance in not an issue. If you would like more info click on this link and check out these pictures.http://www.laneswheels.com/custom_duals.html
Old Oct 3, 2003 | 02:58 PM
Cal's Avatar
Cal
So your's is the pewter SS? Good series of pics with a variety of setups, thanks for posting that link.
Old Oct 3, 2003 | 07:50 PM
MOBE's Avatar
I also have 3" dual exhaust on my car, lowered with Eibach pro-kit. My clearance is just as good if not better than my y-pipe ever was. The lowest point is the driver side off the merge collecter, and that is about 3.5" to 4" of ground clearance.
Old Oct 3, 2003 | 11:17 PM
Cal's Avatar
Cal
MOBE, does your dual exhaust go over the axle or dump before the axle?
