Corsa rasp elimination idea
Old Jan 4, 2009 | 07:34 PM
99ls1bowtie's Avatar
Default Corsa rasp elimination idea
I have a corsa catback, with lts and ory. As many of you know, this is probably one of the raspiest exhaust setups on our cars, and having a cam only makes it worse. Im so tired of it, it is embarrasing and obnoxious and i want to get rid of it. Theres no reason a 1300$ exhaust setup should sound like a farm truck. Before I start, let it be known that I am not going to install a catted y-pipe. I know this will eliminate the rasp, however, i dont want cats. I have done several searches and seen where putting a bullet in the I will help, just not very much. But does anyone have a chambered powerstick in thier i-pipe? i plan on putting one in, with an electric cutout right after the powerstick. im just trying to get some opinions before I do this. What do yall think about this?
Old Jan 4, 2009 | 08:57 PM
TORCHD 02 TA's Avatar
I have GMMG, and i was going to put a PowerPack in my I pipe to get rid of the rasp too.
Old Jan 4, 2009 | 10:01 PM
Really? I was under the impression that GMMG wasnt a raspy system.
Old Jan 4, 2009 | 10:21 PM
ls2 bait's Avatar
i used an slp lm2 in the i pipe and it helped a lot but i still ended up taking it off for a dual dual muffler.
Old Jan 4, 2009 | 10:33 PM
Yah, the only thing that keeps me from ditching the corsa system is that I love the way it sounds outside of the rasp range. I just wanna clean up the sound and get rid of the rasp.
Old Jan 5, 2009 | 05:26 PM
ls2 bait's Avatar
i was in love with the corsa...until the long tubes went on. then i battled the rasp for a year before i gave up.
Old Jan 5, 2009 | 06:58 PM
Weezzer's Avatar
You either add cats or learn to live with rasp.
Old Jan 5, 2009 | 07:01 PM
vader99's Avatar
I had a borla xr1 muffler installed in my ipipe and it made my corsa sound much better even with the ORY and longtubes. Took 95% of the rasp away and deepened the exhaust note at the same time.
Old Jan 5, 2009 | 07:04 PM
LivingCanvas's Avatar
In my experience adding a flowmaster merge to the Y pipe gets rid of the rasp.
Old Jan 5, 2009 | 07:10 PM
No it doesn't.
I have a LTs, Custom 3" O/R Y with flowmaster merge and GMMG c/b and i have reasp like whoa
I am debating between a Borla XR-1 or a PowerPack
Old Jan 5, 2009 | 07:44 PM
vader99's Avatar
I had a flowmaster merge collector in my QTP offroad ypipe along with corsa and qtp longtubes and the rasp was still there. The borla xr1 completely changed the sound of the exhaust. Rasp was nearly completely eliminated and the sound was deeper. The only problem was that the xr1 didn't fit very well in the ipipe. I massaged the xr1 and it wasn't bad but my ground clearance was less. I finally got pissed off at the corsa noise situation and I ripped out the corsa and xr1 and I put in an slp dual/dual muffler (kept the corsa premium tips of course) with a DMH electric cutout in the ipipe and the car is much more pleasurable in all rpm's and is, I think, the perfect exhaust.
Old Jan 5, 2009 | 08:13 PM
SS1875's Avatar
Did you use the round or oval?? length?? and is/was your car lowered at the time?? Sorry for all the ???'s, just thinking of the XR1 for my Borla CB fix.
Old Jan 5, 2009 | 08:21 PM
You still have your Borla XR-1 muffler lying around?
Old Jan 5, 2009 | 08:22 PM
vader99's Avatar
I used the round xr1. I think it was borla # 40085. 15" long and 5 inches in diameter. My car was stock height as well. It worked awesome, sound-wise, but there is just not much room under there.
Old Jan 5, 2009 | 08:25 PM
SS1875's Avatar
Thanks for the info, I appreciate it.
Old Jan 5, 2009 | 08:26 PM
vader99's Avatar
I do, but it isn't round anymore. I flattened the bottom part of it in an attempt to gain ground clearance and I also flattened it a little where it was contacting the rear floorboard area.
The sound didn't change at all with my "massaging," but it did help out with clearances.
Old Jan 5, 2009 | 08:52 PM
You looking to sell it. I am curious
Old Jan 5, 2009 | 09:00 PM
vader99's Avatar
I might be. I never thought anyone would want to buy a "massaged" muffler. LOL
Old Jan 6, 2009 | 07:49 AM
ls2 bait's Avatar
thats almost my exact setup except i built a custom y pipe. i had to keep my premium tips
