Torque setting for crank pulley?
Old Oct 3, 2003 | 07:38 AM
NORB's Avatar
Default Torque setting for crank pulley?
Installing ASP crank pulley soon. Anyone know the torque setting for the crank bolt?
Old Oct 3, 2003 | 09:16 AM
jmX's Avatar
jmX
Default Re: Torque setting for crank pulley?
http://www.ls1howto.com/index.php?category=1
Old Oct 3, 2003 | 11:53 AM
2xLS1's Avatar
The instructions that come with the ASP pulley say to turn the bolt 120 degrees after the 37 ft lbs. The 140 degrees is for a stock cast iron pulley. Whether or not 20 degrees is going to make any difference, I don't know. Just stating what the instructions say.
Old Oct 3, 2003 | 04:12 PM
Dave Carney's Avatar
I've done both (120 and 140 degree) on different ASP installs and it doesn't seem to matter.
Old Oct 3, 2003 | 05:51 PM
soundengineer's Avatar
I thought it was supposed to be 240 ft/lbs of torque????
Old Oct 3, 2003 | 07:43 PM
MOBE's Avatar
The 240 ft/lbs is when you use the old bolt to seat the pulley. Then you use a new bolt and torque it down as stated above.
Old Oct 3, 2003 | 08:33 PM
NORB's Avatar
Thanks guys I bought the pulley used so it didn't come with any instructions.
Old Oct 3, 2003 | 09:07 PM
Smoke_Ford's Avatar
Fully seat the pulley with the old crank bolt, go in good and tight with the new one, you wont have a problem.
Old Oct 3, 2003 | 10:51 PM
Cal's Avatar
Cal
Just make sure you torque it to the above specs. Don't give up when you can't turn it, put a pipe on your wrench! I say this because a few people have had their pulley spin right off the car.
Old Oct 4, 2003 | 02:35 AM
Smoke_Ford's Avatar
I assumed he'd be using a breaker bar. I garuntee most people dont have their crank pulley at 240 ft/lbs
Old Oct 4, 2003 | 09:51 AM
FLA 98TA's Avatar
All of these specs are almost unachievable. Just get it as tight as possible. I used impact on the old bolt then a long bar. Then the new bolt I just used the impact. I have never had one fall off.
P.S. I have done this with both ATI and ASP's
Old Oct 4, 2003 | 11:24 AM
Cal's Avatar
Cal
I got mine torqued close to 240 fl-lbs by using a one-inch drive breaker bar with a four-foot length of pipe slid over the handle. If it spins off when you are going fast, it can hit the bottom of the car doing damage. Also, one guy I heard about never could find his pulley. That's an expensive pulley to loose.
Old Oct 4, 2003 | 02:51 PM
dam...you all are weak if you can t get it to 240ft/lb...I was on the ground under the car....had the thing in 4th gear with the parking break on....had a buddy mashing down the brake pedal I had enough torque to turn the back wheels still....so I put it in 6th and pulled it again.....got the torque wrench to click over...set at 240ft/lbs of torque(of course this was a stock pulley and bolt)....man y'all are weak.
