project ls6 intake begins!
Old Jan 13, 2009 | 08:47 PM
MattysTA's Avatar
Default project ls6 intake begins!
so im going to take the ls6 intake i got and convert it to a 90mm tb using an ls2 intake i picked up for a 100 bux. tomorrow ill post some pics with the tb snout cut off and then ill post more pics when its done. once my trans is fixed ill take the car to the track with the ls1 intake on then swap to the ls6 and go back to the track to see what i gain. i might leave the current tune alone to see what it gains without changing it. i havent decided on that yet.
Old Jan 13, 2009 | 08:58 PM
jrob56's Avatar
subscribing...take plenty of pics maybe you can do a write up on this if it proves worth it.
Old Jan 17, 2009 | 01:33 PM
qwk93ta's Avatar
I'd like to see PICs too......
Old Jan 17, 2009 | 01:43 PM
01ssreda4's Avatar
how are you gonna bond the two plastics together??? does the ls2 intake have a factory 90 opening....
Old Jan 17, 2009 | 01:56 PM
devilsalmostfree's Avatar
any pix yet?
Old Jan 17, 2009 | 02:09 PM
00Antivenom's Avatar
Subscribed and interested.
Old Jan 17, 2009 | 02:14 PM
00_STANG_KILLER's Avatar
Subscribed Good Luck hope it turns ino a cheap 90mm MOD....
Old Jan 17, 2009 | 02:24 PM
LS1-NAVY's Avatar
this could be good or bad but im gonna subscrbe
Old Jan 17, 2009 | 02:42 PM
01ssreda4's Avatar
^^^pass or fail this is worth watching. if he does it i am gonna be the next to hack mine up...
Old Jan 18, 2009 | 12:59 PM
MattysTA's Avatar
Default Pics
Sorry guys i've been busy with other things and havent had the time to work on this. here are some pics of the way everything looks at the moment. as you can see i left alot of material on the ls2 tb opening so it can be trimmed down little by little so i can get the fit im looking for. i allready trimmed it down a bit and will probably trim it more. im going to attach it to the intake by using a plastic welder once i get the final fitment.
Old Jan 18, 2009 | 01:09 PM
10 bucks says he pulls it off.
Old Jan 18, 2009 | 01:40 PM
TORCHD 02 TA's Avatar
just in for results
Old Jan 18, 2009 | 02:01 PM
99_Z28's Avatar
in! Hope it works out... it would suck to throw $400 out the window.
Old Jan 18, 2009 | 02:54 PM
jrob56's Avatar
no **** that would be rough...
Old Jan 18, 2009 | 04:24 PM
Mike94ZLT1's Avatar
I would have cut apart a stock LS1 intake and tried to put it back together before doing this to something valuable...
Old Jan 18, 2009 | 05:12 PM
MattysTA's Avatar
i wouldve done it that way but the person i bought the ls6 from didnt pack it properly and it got to me with the port for the vacum broken off so it has to be repaird anyway(theres a big hole in the back of the intake now) so i figured wth...
Old Jan 18, 2009 | 05:16 PM
01FbTaWs6's Avatar
nice. I am subscribing. Cant wait to see how this turns out. i was thinking of doing the exact same thing.
Old Jan 18, 2009 | 05:20 PM
3.8redbird's Avatar
my intake sucks
Old Jan 18, 2009 | 05:21 PM
Alt's Avatar
Alt
Subscribed
Old Jan 18, 2009 | 05:31 PM
will01's Avatar
signing up
