FTRA/SSRA guys, come in
Old Jan 20, 2009 | 03:48 PM
Mrwilson's Avatar
Originally Posted by chrs1313
Yup I thought I typed that...you can’t have a great ET with a shitty mph...but the opposite is true(you can have a shitty ET with a good mph)...
comparing ETs only works if you have the same 60ft…which is a lot harder to do than just looking at mph which is pretty much independent of 60ft…
whether I 60ft a 1.8 or 1.4 my mph will still be right around 122…try to say the same for ET…
When you spin you mph higher, either way there is no good way of telling ANYTHING if you dont make a good pass. Learn to take off, get consistant results, read et.
Old Jan 20, 2009 | 05:31 PM
Fast Toys Performance Parts's Avatar
Originally Posted by Mrwilson
Lets see exactly how much you people know about what you are talking. Basic question here: Where is Mph measured and how is it measured?
Up to 1989, there were three timing lights at the end of the track; one AT the end of the quarter mile, and one 66 feet before, and one 66 feet after. The middle light was used to calculate the et of the run, and the time to travel the 132 feet at the end of the track was used to calculate the trap speed. This gave the average speed at the end of the track, but you can see what this lead to. Most of the racers stayed on the gas for an additional 66 feet past the quarter to get a consistent speed to evaluate their setup. The track's 'shut down area' of course is a fixed length, but the pro racers were starting to hit 300 mph plus by the end. In an attempt to get these guys off the gas 66 feet earlier and 'make' the cars appear slower, the NHRA stopped using the last light around August of 1989. Today, the trap speed is calculated between the light at the quarter mile and the one 66 feet before. So any timeslip after 1989 is really giving the average speed 33 feet from the finish, which is pretty close to one percent slower than before.
Old Jan 20, 2009 | 05:53 PM
chrs1313's Avatar
what would you condsider a spin then...i can go off idle and not spin and run a 11.30 with probably a 1.80 60ft...with the same mph if i were to stall it up and launch hard with a 1.4 60ft with a 10.80...both runs will give right around 122mph...
compare what you want but i will use MPH over ET any day...basically no difference(mph) to 1/2 sec(ET)
Old Jan 20, 2009 | 09:07 PM
Mrwilson's Avatar
nice copy paste. they consider that plagerisim
Old Jan 20, 2009 | 09:09 PM
Mrwilson's Avatar
thats because you have a car with some converter. it allows the engine to be more consistant by keeping it in its power band. stock converter cars have to lug thru the first few thousand rpm because the converter is locked up
Old Jan 20, 2009 | 10:12 PM
thunderstruck507's Avatar
fasle. converter will not lock under WOT unless forced to do so.
Old Jan 20, 2009 | 10:27 PM
Mrwilson's Avatar
tcc lockup isnt what I mean by having the trans ******* not slip
boy you guys dont really know much of anything arround here do you?
Old Jan 21, 2009 | 12:42 AM
Ironxcross's Avatar
Old Jan 21, 2009 | 03:24 AM
green28's Avatar
Someone got some sand in their vagina?
Alot of variables when it comes to looking at ET (ie. great launch, wheelspin, ect.) but MPH will usually be consistant. I've ran a 13.06 and I've roasted the tires to a 15.0 and both runs were at 108 MPH. From what I gather from other threads, you can expect to drop about .1 to .2 in et with said product.
Old Jan 21, 2009 | 05:20 AM
MikeG's Avatar
I have yet to see you say anything that would make anyone here believe that you
have any idea what you're talking about. You just came in here and hijacked the OP's thread
with your own silly question.
Old Jan 21, 2009 | 06:30 AM
chrs1313's Avatar
So now it is the converter…haha
I give up…
Old Jan 21, 2009 | 07:16 AM
  #32
03Sssnake's Avatar
ROFL...total thread jack. Mrwilson is that d-bag we all work with, you know the guy that knows way more about cars than the rest of us, likes to stir the **** for no apparent reason, other than he likes the smell of ****. Claims to go over 200mph on a regular basis etc etc...
Old Jan 21, 2009 | 07:19 AM
  #33
Lopoetve's Avatar
if you know so much, why don't you just leave?
That would make more sense than flaming a sponsor, after all.
Old Jan 21, 2009 | 08:13 AM
  #34
slickone's Avatar
It sure would be nice to get back on the original subject.I have also been trying to find out as much as I can about that.All this
Old Jan 21, 2009 | 01:06 PM
  #35
Mrwilson's Avatar
lol, i wish you guys knew what you didnt know. then you could laugh with me at you.
anyways, go back to the topic at hand. I sha'nt intervene any further. Have fun living in your ignorance and driving your obsolescence.
