FTRA/SSRA guys, come in
1. What is your difference in IAT temp when stopped and moving in relation to the outside temperature
2. What is your MAP at when you're WOT.
3. Coolant temperature, if you have a way to measure that.
Numbers please, not "it feels like..."
You can also check www.installuniversity.com for the data they collected.
Here is a link to the install university review:
http://www.installuniversity.com/ins..._12.262000.htm
The FTRA does more than just lower IAT's. It also increases the V.E of the motor by creating a mild pressurization of the intake at higher speeds.
Sorry we didn't mean our answer to come off harsh. We just didn't think you wanted our company to provide the data the OP was asking for. It sounded like he was asking people on LS1TECH.
If anyone has a question about our product, please call us at 877-955-4896 or email us at sales@fasttoys.net . We don't always have time to watch the message boards to catch questions on here.
Here is their test info:
The test runs were made in the first three gears of a six-speed LS1. That puts the LS1 rifling along at 100 mph plus at the end of the test run, just like at the nearest quarter-mile drag way. In first gear, the VE showed no gain. During second gear, an increase of 0.9 percent was shown over the stock configuration. Third gear showed the exact same increase over the stock configuration. A 0.9 percent increase in volumetric efficiency stuffs an extra 31 cubic inches of air into the engine.
Equation 1
A 0.9 percent increase doesn’t sound that great. A typical LS1 with ported heads, cam, headers, etc., will gain a seven percent increase in VE (100 horsepower). This is very important to note. Assuming that the VE is directly related to the amount of horsepower added (on a natural aspirated LS1), a 1% increase results in a 10 – 15 horsepower gain (see Equation 1).
Most of our customers report 1-1.5 MPH in the 1/4 mile as a typical gain after installing the FTRA.
Equation 1
I was hoping you had a scientific test at the track for your car, I assume you do not? I also am not as concerned with mph as most people tend to be, I prefer to know the ET differences on back to back runs. I would also like to ask how you calculated VE in this senario as well as how you calculate that a 1% increase in Voulmetric Efficiancy equates to a 10-15 horsepower increase. I hope I dont sound irate, but rather curious.
If you read through the install university article, they explain how they calculated the VE and corresponding HP increase. They include a link to a spreadsheet so you can caculate your own.
The typical gains we have seen in testing and reported from our customers is 1-1.5 MPH in the 1/4 mile which is 10-15 HP on a 3400-3600 lb car.
As the other LS1TECH member mentioned, when we test products in the 1/4, we look at MPH increases. MPH increases are consistent from run to run. ET changes are not consistent because they are so dependent on traction from the launch.
, its okay though, we were all there once...FTRA has shown you multiple situation that proves the system works...here is a test for you with a huge FTRA in a way...
https://ls1tech.com/forums/generatio...sults-tom.html
also mph is the teller of how much power a car is making...you cant have a great ET with a shitty mph...but the opposite is true...mph will always be pretty close, independent of traction...so that is why it is better to compare mph to tell the tale of how much power was gained...
I'd answer if I could, but mine is still in the mail
FedEx man brings it friday!
comparing ETs only works if you have the same 60ft…which is a lot harder to do
than just looking at mph which is pretty much independent of 60ft…whether I 60ft a 1.8 or 1.4 my mph will still be right around 122…try to say the same for ET…
