Does Anybody With A 160F TStat Really Run at 160F?
temp 'stats really runs at the thermostat
setpoint. Seems that most advice is to use
the low temp 'stat but run the fans at 185.
So you might run at 160 on the highway, but
not around town. If you have set up for true
160F operation, what did it gain and cost you
(timing margin, HP, economy)? Why not use a
180F 'stat and run it at 180F instead of a
160F with 185F fans?
And, any info on the real ECT seen with the
various lower-temp 'stats on the highway would
be interesting.
runs a solid 194F. If GM calls that 180, I guess
I'd want a GM 160. But don't know the different
brands' relation between what they sez, and what
they does.
The coolant temp above the t-stat opening point is determined by the engine heat the cooling system capabilities (radiator capacity, fans, etc.) and ambient temp.
they does.
"Most racers know that a cooler running engine is a better performing engine. By reducing the temperature at which an engine runs, it will make more power through better thermal and volumetric efficiency. SLP has just released a new 160 degree thermostat for all LS1 equipped Corvettes, Camaros, Firebirds. This new thermostat replaces the <font color="red"> factory 195 degree unit<!--color--></font>, allowing coolant to circulate at lower engine temperatures, keeping the engine cooler...."
Although SLP normally "dumbs out" there descriptions so everyone can understand them, they have the basic idea. This is only to a point, however ... Every engine has an optimal range for power and efficiency.
