Boom tubes? Flat side exhaust exits....
Old Oct 10, 2003 | 05:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Boom tubes? Flat side exhaust exits....
You can run mufflers right off the headers.
Old Oct 10, 2003 | 07:47 PM
NightHawk's Avatar
So, you'd essentially have header collector mufflers, right? If it's straight through bullets you're talking about, why NOT do it? Anyone with exhaust knowledge know why he should not do this?
Yeah, but isn't the only place you have enough room for a crossover after the trans tailshaft? So you'd have to have to use extension pipes after the headers, then crossover pipe, then bullets, then boom tubes. Would there be enough room for all that?
Without the crossover like they said, you'd have "collector muffler" sytle bullets, then boom tubes. Or maybe headers, then bullets, then crossover, then boom tubes. That'd be cool Do it Nata!
Old Oct 11, 2003 | 10:26 PM
NataSS Inc's Avatar
I made a couple calls back east to a guy that does a "little" work on those cars that make alot of left hand turns. He said he is going to try and get me what I am looking for.
He said the only trouble with getting the used stuff is that its pretty beat up after a run, but the new stuff from Dr. Gas is spendy as hell. So I opted to go with the cheaper dollar figure and not worry about looks.
We will see what happens.
I will run the bullets right off the headers then to the crossover then to the boom tube.
Old Oct 12, 2003 | 10:24 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Nice! Pics when done please!
Old Feb 3, 2004 | 08:09 AM
BMF's Avatar
BMF
I've been looking at doing this for a while. I actually plan on running some spintech mufflers off of the headers into an x pipe and running single boom tubes out of each side. I've got the aero package on my Z so I actually plan on cutting into the gfx for a little more clearance. My old roomate was running an x pipe with dumps before the axles. It definitley wasn't quiet but it was deep and had no rasp. Where as I have hooker lt's, an offroad y into a loudmouth, with a bullet instead of rhe resonator. My exhaust puts his to shame loud wise. I'm hoping by going to this new setup it actaully quiets the car down a little and gives it more of a deep throaty rumble with little to no rasp. The only thing I really worried about is the heat issue but I'll deal with that hurdle when I get to it.
Old Feb 3, 2004 | 10:50 AM
NataSS Inc's Avatar
I should have mine on within the next few weeks. Priority is just getting the car running right now though
Old Feb 3, 2004 | 04:54 PM
HOSS's Avatar
you guys need to talk to Turninlt4 on here, hes got a 97 ss with the boom tube setup, used to have spintechs on there, but they hung to low, but he does have the exit on both sides, its ungodly loud, ****** awesome really, only drawback is smelling like exhaust all the time, id do it, but he got to it 1st....
Old Feb 3, 2004 | 06:12 PM
Black 98 T/A's Avatar
yeah listen to hoss george has the boom tubes with a dr. gas x pipe. fuggin awesome.
Old Feb 3, 2004 | 07:15 PM
Turnin'LT4's Avatar
I got boom tubes.
What do you guys want to know?
Old Feb 3, 2004 | 07:20 PM
Turnin'LT4's Avatar
here is a side pict
Old Feb 3, 2004 | 10:10 PM
NataSS Inc's Avatar
sound clip or vid?
Old Feb 4, 2004 | 11:46 AM
  #32
Turnin'LT4's Avatar
I have a video but it isn't a very good one. I will take some more when i get my car out of the roll cage shop and put in the rearend. I can send you the video if you want though.
Old Feb 4, 2004 | 11:52 AM
  #33
Turnin'LT4's Avatar
Just to respond to your earlier post on page 2 i think. The boom tubes actually scavenge. They have a crossover hole abotu every 3 or 4 inches in teh dividers within' the boom tubes. They really help with torque. I picked up 12 ftlbs just going from open X to boom tubes. I also lost no HP
Old Feb 7, 2004 | 05:25 PM
  #34
ta12sec's Avatar
Has the heat hurt your paint at all ?
Old Feb 7, 2004 | 06:41 PM
  #35
strokedls1's Avatar
I did a 3" x-pipe with fake pup cats and 3" bullets out the sides. Clearance sucks, sound is a little loud. Not too bad cruising on the freeway. Cool factor is two thumbs up. Heat is not issue. I wrapped the fuel and brake lines with heat shield tape. I have pics and a burnout clip if you want email me jmh75@earthlink.net
Old Feb 16, 2004 | 01:36 PM
  #36
1CAMWNDR's Avatar
Originally Posted by NataSS Inc
sound clip or vid?
NattaSS, did you get yours installed yet???
Old Feb 16, 2004 | 01:39 PM
  #37
NataSS Inc's Avatar
Not yet. We just got the car running 2 weeks ago and I am still sorting 1 issue with it. Its a quick fix though. As soon as the weather here in seattle clears up enough it will be going through emmissions. and right after that.....the boom tube!
Old Feb 18, 2004 | 01:14 AM
  #38
NataSS Inc's Avatar
Boom tube might in on saturday. We will be test fitting it then at the exhuast shop and if he thinks he can do it, it will go in. No reason why he shouldnt, this guy has done some VERY trick stuff in the past. I am trying to get one of the local guys to come and get some vid.
Old Feb 18, 2004 | 02:49 PM
  #39
1CAMWNDR's Avatar
Kick ***! Can't wait to see it and hear it!!
Old Feb 19, 2004 | 11:53 PM
  #40
TKhawk01's Avatar
What if some one designed some custom ground effects that hung lower that would have room for the tips with out having to flatten the pipe out too much. It would also make the car look lower for those of us with low hangin headers that cant go any lower.
