My catch can routing ok?
Didn’t really say anything. I went off routing on my old truck.
This is what is called as the dirty side of the PCV system. The fresh side was a hose from the front facing port on the passenger valve cover to the port on the throttle body and if no port was there then into the air lid or bellow between the MAF and the TB. If installing a sealed catch can just connect it up as mentioned above but instead of the hose going into the intake manifold run it to the inlet side of the catch can and then the outlet side to the intake manifold.
I have the later LS6 valley cover with built in PCV
And LS6 intake
5.3 Truck valve covers (which have on 1 hose connection on each)
5.3 TB.
Engine is 5.3 NA.
I also have a twin catch can.
So do I do as follows:
Clean side
Connect Intake connection to inlet on Clean side air catch can then outlet to both Valve covers (to supply fresh air into valve covers and hence crankcase)
Dirty side
Connect Valley cover outlet to inlet on Dirty side catch can then outlet to TB connection
Does this sound right?
Like this...?
Here is how I recommend connecting your PCV system based on the information provided. Keep in mind that a catch can will not fix mechanical issues. If the engine is too loose, burning oil, etc, a catch can will do nothing to help these conditions.
[IMG]http://www.andersonperformance.net/LS2 Single PCV NA.jpg
9 years later. I just found this thread. I have my catch can set up exactly like this. The only difference is my check valve is the opposite direction.
I thought suction comes from the TB. pulling through both valve covers. dirty goes in from the valley cover port. Ill upload a pic and thats probably why my can doesnt get much action. The intake stays decent from oil residue but Ill swap it around when I get back to the car next week.
*further- it is extremely dangerous to follow some online-found schematic vs. the one provided by the manufacturer. accidental error on the engine ventilation strategy can shorten engine life or cause immediate damage.
-if your catch can did not come with info on how to hook it up, it is probably not the best investment.
The thing is there are so many LS setups out here that most cans don't have a diagram for each variation. For instance with or without the LS6 valley cover. Some valve covers have dual ports on the passenger side as pictured and some don't. No one supplies diagrams for all of the possibilities. So we come here . My can is one I made with baffles and all, a check valve is also under the breather to keep unmetered air from coming in but will allow air out if its enough pressure. I have another one on the bench now smaller in size and built a lot better. I like it when I do it myself.
One last question though if I removed the check valve all together. Would that make this routing righteous?
I REALLY appreciate the feedback.
since i did not build your can i have no way to tell you what it can or cant do vs. what you want it to do, or how it should or shouldn't be hooked up besides an educated guess.
if you like to do it yourself then you are forfeiting the customer support that comes along with a product like mine where this is guaranteed to be figured out for you along with superior performance.
TBH i dont go through 200 of these a month because they are easy enough for everyone to figure out what they need, or figure how to make it, or how to hook it up, to get the job they need done to enjoy their hobby.
if you want to send me some pics of the car and your can to mightymousesolutions@gmail.com i will tell you what i think it will do and won't do, and you can decide if that is good enough for you. not going to say what magic sauce is in mine etc. because that info has cost me years and years of development and plenty of dollar bills. I hope you understand.
And LS6 intake
5.3 TB.
Engine is 5.3 NA.
Clean side
Dirty side
Like this...?
I do not have the connection at the throttle body as shown in this diagram in Green (supply to clean air side catch can).
Can I connect it to a pipe connection on the air intake pipe (before the throttle body)?
Like this?
Doesn't this leave unmetered air in the circuit?
Anyways I don't have all the pieces I guess to hook this thing up to the left hand valve cover.
The car has a Chinese catch can on it (D1 Spec)? which appears to be of decent quality but I'm sure it's a cheap piece of crap. It does have oil in it so maybe it's doing something lol.
I would like to hook it up like this..............
You know the standard picture that has been floating around for years now.
The car has an inline PCV valve that is in a similar location to whats posted above. Not sure if its factory or not. The car had the stock molded y pipe and was hooked up to both nipples on the passenger valve cover. It makes sense in my head to do the block off of the rear nipple on the passenger valve cover.
Two main questions
Should I block off the rear port on the passenger valve cover?
What part do I need to go into the grommet on the drivers valve cover?
MightyMouse has me a little intimidated on this project as I'm not really familiar with the LS engine PCV stuff.
Last edited by Mr. Black; Feb 2, 2019 at 09:49 PM. Reason: Corrections from typing too fast.
The parts you need on the rear side of the driver valve cover is:
DORMAN 42056 pcv valve grommet O’Reilly Autoparts
Watts Nylon Hose barb A-295 3/8 in ID x ¼ in MIP – Home Depot
I welded -AN fittings onto my valve covers so that it looks nice.
https://ls1tech.com/forums/generatio...look-good.html
If you are trying to piece together an existing PCV system with a catch can, then you might have troubles.
1. Smell like **** for a street due to venting off in the engine bay
2. Result in blown rear main seals due to improper pressure release
