LS1 vacuum port removal.
Old Jan 27, 2009 | 06:51 PM
radiowaves88's Avatar
Default LS1 vacuum port removal.
Just wanted to know how to remove the vacuum port at the rear of my LS1 intake. It has two ports and the MAP sensor mounts to it. I have removed the sensor but don't know how to get the port out of the manifold. Thanks for your help.
Old Jan 27, 2009 | 08:13 PM
S10xGN's Avatar
It's been awhile, but I *think* you push inwards to compress the seal and turn counterclockwise a quarter turn. See if that does it...
Russ
Old Jan 27, 2009 | 08:34 PM
Thanks, I'll give it a try.
Old Jan 28, 2009 | 01:48 PM
Nope, still can't get it out. Any other suggestions?
Old Jan 28, 2009 | 07:49 PM
S10xGN's Avatar
My manifold was broken when I got it, but here's a good pic of it disassembled. I still think it was a quarter turn, maybe tight because of the o-ring?
Russ
Old Feb 22, 2009 | 07:16 PM
DrumFunKen's Avatar
Does anyone know what the part number is for that piece? I broke mine and need to replace it. Any of you guys have a spare.
Old Feb 22, 2009 | 09:43 PM
massls1guy's Avatar
That piece doesn't have it's own part number, it's included with the manifold assembly. I would look in the for sale section for a used LS1 intake, they are pretty cheap.
Old Dec 2, 2014 | 11:47 AM
mightyquickz28's Avatar
As you can see in that picture, that guy broke his. That piece is NS(not-stocked, non-service) and is considered to be an integral part of the intake. If you look closely at that port piece, you'll notice it has multiple retention barbs/tangs. It is meant to snap into the manifold when pushed in. To remove that port, you have to have the Throttle body removed and then, using something long, strong and narrow, push the detent inwards while using your other hand to provide a "pulling outward" action on the port. Once one of the clips is pushed inward far enough, the pulling force of your hand should be able to pull that side out and then you can get the port out fully.
Old Dec 2, 2014 | 04:05 PM
Paul Bell's Avatar
That's MISTER MODERATOR
hahaha Mighty, didja see the date of the post you responded to?
Old Dec 2, 2014 | 05:29 PM
Yeah, it's ancient by internet standards. But I've been looking for references on what ports on the LS1 intake go to and I came across a couple that were misleading ("Twist it") and I just wanted to set the record straight in case someone else came across this post. NYC, eh? Nice to see!
I'm near Albany and putting together a 5.3 with PT7675 turbo, Wiseco Pistons, Callies Rods and Isky Triple 12 cam. Hope to have it all together by next Spring.
Old Sep 21, 2017 | 07:58 PM
BrianAU2017's Avatar
Default 1999 LS1 fixing in 2017
im thankful there’s people who are not afraid to revive old posts. I searched for this because I am trying to get everything away from the oil pressure sender to replace and might leave this vacuum port alone it’s even a bugger to get the hose off I don’t want to break it.
this thread helped me a bit
Old Sep 21, 2017 | 10:09 PM
01CamaroSSTx's Avatar
That's what it's here for. I've found it to be both helpful and hurtful at times.
Old Aug 18, 2021 | 05:55 AM
destructy's Avatar
Default Thankyou
Agreed. Ancient thread that needs love.
This thread was first in google in my quest for knowledge and proved the most useful and relivent.
(Needed to give offering to tech gods)
