Pacesetter headers better than SLP headers
Old Oct 8, 2003 | 04:37 PM
Y2KSS's Avatar
Default Pacesetter headers better than SLP headers
I just ordered heads and cam for my 2000 SS A4 and right now I have SLP longtubes. I am thinking about changing to Pacesetter longtubes when I install the heads & cam. Just wanted to get some opinions on the two. Thanks
Old Oct 8, 2003 | 04:43 PM
ssfiress's Avatar
Default Re: Pacesetter headers better than SLP headers
screw SLP lt's. go with the pacesetters by far.
Old Oct 8, 2003 | 05:08 PM
jrp's Avatar
jrp
SN95 Director
i'd keep them if you already have them, there fine unless you plan on lowering your car. i doubt you'll gain any signifigant hp from switching to the pacesetters from the the slp's.
Old Oct 8, 2003 | 07:39 PM
Y2KSS's Avatar
Anyone else have any opinions or any information on these?
Old Oct 9, 2003 | 12:48 AM
WOT's Avatar
WOT
i have the slps and a friend of mine....with the same mods...gained 10 rwhp with the changeover. slp's are a bottleneck for sure. not that they are awful headers, but there are better ones out there for a lot less cash!
2 SLOW's Avatar
Just keep the SLP's. They make fine power and are stainless steel. It wouldn't be worth it to change headers.
Old Oct 9, 2003 | 10:18 AM
Y2KSS's Avatar
Well, I have 2 for and 2 against the header swap. Anybody else want to put their 2 cents in?
Old Oct 9, 2003 | 11:01 AM
Cal's Avatar
Cal
I think both sides are right . . . the SLP headers are Stainless Steel, but have lower power output and hang low. The question is, do you want to spend $725 on some QTP's (also stainless) to gain 5 to 10 hp? I think the tie breaker would be if you need the added ground clearance. You could also pass off the SLP's on some sucker and get some of your money back.
Old Oct 10, 2003 | 12:20 AM
bluestreak98's Avatar
pacesetters are like 275 brand new
Old Oct 10, 2003 | 12:23 AM
H b K l U n A's Avatar
this is why you dont buy SLP LTs....
Old Oct 10, 2003 | 03:40 AM
LS1MONSTER's Avatar
Damn man..did you forget to bolt the headers to engine or something! I'm lowered with SLP lt's and don't have a single scatch on them. I've only rubbed maybe twice and that was on the Y-pipe. I say stick with the SLP's the gain wouldn't be worth the extra cash if any. Pacesetters may be cheaper but have fun when it comes to the "great" "fit" and "finish". My SLP's fit and finish was excellant to say the least. There are alot of cheaper LT's out now.. but I have read and heard of people complaning about them not fitting correctly or lining up with the y-pipe. I'm very satisfied with my SLP's. I would say stick with them. If anything check out QTP lt's. Just my 02.
Old Oct 10, 2003 | 01:34 PM
KRAZY K 2000 TA's Avatar
Hey did somebody steel my SLP lt's those pictures look like mine
