TB question, need answer asap plz
Old Feb 8, 2009 | 09:59 PM
Swift_01_z-28's Avatar
Exclamation TB question, need answer asap plz
I am planning on buying a p&p tb off a 99 z28 and am wondering if I can just bolt it up to my ls6 intake mani. I know I need to plug up the hole for the vaccum line, but is there anything else to worry about? I did a search on here, but it didn't turn up anything useful. Any help would be awesome guys, I was gonna get it tomorrow or the next day.
Thanks,
Edde
Old Feb 8, 2009 | 10:03 PM
redbadss's Avatar
the cam gear on the throttle body will be a different size than yours, 98-00 had a smaller cam gear on the throttle body, 01-02 had a larger cam gear
the throttle body itself will bolt up perfectly fine, the cam is where the problem will be at
Old Feb 8, 2009 | 10:12 PM
There isn't anything I can do about that is there?
That means I probably wouldn't be able to use it huh?
Old Feb 8, 2009 | 10:14 PM
redbadss's Avatar
yea i'm pretty sure the throttle cable will be too long in your case,
Old Feb 8, 2009 | 10:15 PM
You can shorten that up though can't you? BTW, where abouts in oklahoma you at?
Old Feb 8, 2009 | 10:20 PM
redbadss's Avatar
not really sure if you can shorten up the cable, i'm in the northern part of oklahoma in bartlesville which is about 40 miles north of tulsa, if i was you i would wait til i found a p&p tb off a 01-02 to save all the trouble..
Old Feb 8, 2009 | 10:25 PM
Yeah, that's what I am thinking. Thanks for the help man.
Old Feb 8, 2009 | 10:28 PM
redbadss's Avatar
yea no problem man
Old Feb 9, 2009 | 05:12 PM
ricernomore's Avatar
yes you can shorten the cable
Old Feb 9, 2009 | 06:29 PM
tasales06's Avatar
swap the cam gear from your current throttle body to the new one your buying
Old Feb 9, 2009 | 06:36 PM
nemss1's Avatar
just buy a cable frm 98 car. thats the only dif is cam sizes. other than that, they just bolt right up with the same connections
LS1/LS6 TBs are the exact same so yes they will bolt up to an LS6 mani. 98 TB is the only dif. has smaller cam
Old Feb 9, 2009 | 07:45 PM
bobbyd's Avatar
you can shorten up the cable.
i have a ported tb from a 99 on my 02.
Old Feb 10, 2009 | 09:41 PM
Thanx guyz, but I'm just gonna take it and have mine ported next week.
