ported FAST 90/90 overkill on cam only? NOPE
enough proof for me!!
link in the Dyno Forum
not only did it make more power peak, but it made a pretty considerable gain across the rpm band.
first run is ls6 with ported TB....2nd is with the ported FAST 90/90. car never came off the dyno during the swap.
thanks....i was pleased.
i was hoping to make more before the swap...since i had upgraded the flywheel, exhaust and waterpump.
but then again i also went from 245 tires to 315s
i told myself going in that i "wanted" 415-420rwhp....but would be damn pleased to get a realistic 410rwhp.
so going just shy of 409 made me
might need to do one of these comparisons with a nice set of milled TFS "as cast" heads.
thunder that's great that you don't feel it justifies it. but once you've exhausted most other avenues of power gains...you're stuck with the big stuff.
and if you search like i did, you can find good deals and save A LOT of coin.
i paid $1200 shipped for the lightly ported intake, gaskets, hardware, Throttle Body, stock ls1 fuel rail (didn't need but was included)....AND a set of cleaned and flowmatched Bosch Green Top 42# injectors.
that's better part of $1600 worth of parts....for $1200
and my $60 dremel tool did the final porting that i think really helped the setup.
the $300 i sold the LS6 intake and TB....made it even better.
for those of us who can't afford heads and all the misc parts they require...or who don't have the means to install heads....this makes a GREAT upgrade.
i think it was well worth the money
I'm not bashing anyone who buys one, but its just not something I see myself doing. But my car is a daily driver too...and I also have plenty of room to do heads in the car in a snap too.
I wouldn't mind to get my hands on a good 78mm FAST for cheap that I could port myself and maybe open up the inlet some more (heard you can do up to 85mm iirc)
It would be great if someone would get off their **** and make a comparable intake so they couldn't get away with the robbery they charge for a hunk of plastic. To me its more that principle that deters my interest. Just like $100 Affliction t shirts and Rayban sunglasses...just not my thing.
Great gains either way though.
"Car never came off the Dyno correct? Was this a tuned car with a Ls6 and ported T/B and then did just a swap to 90/90, or did you retune the car for the 90/90?"
car was tuned (since its had a cam for 4 yrs) before the intake
swapped the intake
retuned.....redynoed....results on the graph
swapped the intake
