magnaflow
With either of those setups, you can't go wrong. It is nice with my setup that you can be obnoxiously loud one second, but can be quiet if you need to (ie. cops, or if you'd like to carry out a conversation in the car).
http://www.youtube.com/watch?v=D2IsjxLb6d4
http://www.youtube.com/watch?v=FRIIx...eature=channel
http://www.youtube.com/watch?v=leqiQ...eature=channel
I ended up going the other way as you can see from my sig, came across a good deal and jumped on it, well see if it was the right one after spring break!
The install was pretty simple. I-pipe to Over-axle pipe. Over-axle to muffler. Then add the muffler exits w/tips. Attatch the hangers on the exits to the rubber mounts. Adjust to the look you like and you're done. The only trouble we had was with one of the Driverside hangers. The rod (the one closer to the axle) that hooks into the factory rubber mount seems to be way too tall. Dave wants different tips so when he takes the car to a shop to have them installed he's gonna have that hanger modified to fit correctly. We have a large Zip Tie holding it with the mount for now and it's not going anywhere, so like I said we're happy with it. Pretty easy.
