header bolts
Old Feb 26, 2009 | 08:31 AM
Nick_Rapitis's Avatar
now swapping headers doesnt sound that good lol
Old Feb 26, 2009 | 08:37 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Well - it doesn't happen to everyone. Mine came out just fine, and I'm getting ready to do another swap in the spring, this time removing Stage 8 header bolts.
I've had a friend that broke a head bolt (not header) while doing an install, so freak things can happen...you just have to be prepared for the worst, and is why I'll only recommend people doing this type of stuff if it isn't their only mode of transportation. When I did my first header install, my Camaro was my only car - I did the install on a Sunday, and barely had a running car by Monday morning to get to work just due to complications (getting the old exhaust off was a bitch).
Old Feb 26, 2009 | 08:38 AM
how much does it cost typically to have it done?
Old Feb 26, 2009 | 08:47 AM
MeentSS02's Avatar
A header swap? I have no idea - never priced that one out. The best thing to do is find a buddy or two that have done it before on your type of car to help walk you through it - a couple of beers and the right tools should be all it costs.
Old Feb 26, 2009 | 09:18 AM
yeah im sure i could handle it but if say one of the bolts snaps off in the block when im removing the stock manifolds im screwed cuz that is something i couldnt fix...if i had some shop do it i wouldnt have to worry about it...
Old Feb 26, 2009 | 11:29 AM
03Sssnake's Avatar
FWIW, I never had one break on removal, it was on installation when tightening (apparently too much in my case). You might go aftermarket for header bolts/studs (stage8, pearcys, and or ARP)
Old Feb 26, 2009 | 11:33 AM
MeentSS02's Avatar
Risk vs. reward - only your bank account and your level of comfort can decide.
Old Feb 26, 2009 | 11:43 AM
speaking of tightening is there a specific amount header bolts need to be tightened?
 Michael S. Palmer
Old Feb 26, 2009 | 11:46 AM
03Sssnake's Avatar
18lbft is the spec from the factory.
Old Feb 26, 2009 | 11:52 AM
03Sssnake's Avatar
Really not that big a deal, installed several sets reusing stock bolts with no problem. Just got me that one time.
Old Feb 26, 2009 | 12:02 PM
MeentSS02's Avatar
I think it is 11 lb-ft on the first pass (starting in the center and working out), then 18 lb-ft on the second pass. You may not be able to get a torque wrench on all the bolts though - it can be pretty cramped working under the cowl.
Old Feb 26, 2009 | 12:05 PM
  #32
99bowtieZ's Avatar
It really isn't too difficult, if you are even slightly mechanically inclined then it would be a walk in the park(a long walk the first time).
Old Feb 26, 2009 | 12:13 PM
  #33
vsocks1's Avatar
It is not that bad to do yourself. A shop will likely charge $350-$500 for the work.
Old Feb 26, 2009 | 12:39 PM
  #34
so 11 lbs? ok...tell me more about the order of tightening them...i would have done the ends first and worked towards the middle...
Old Feb 26, 2009 | 12:40 PM
  #35
and what do you mean 11 on the first pass and 18 on the second pass?
Old Feb 26, 2009 | 12:43 PM
  #36
99bowtieZ's Avatar
Tighten them all to 11 before you tighten them all to 18.
Old Feb 26, 2009 | 02:11 PM
  #37
MeentSS02's Avatar
www.ls1howto.com
Your answers are there.
Old Mar 4, 2009 | 06:23 PM
  #38
SSmoken's Avatar
how did you fix it?
i didnt lol.
Old Mar 4, 2009 | 09:02 PM
  #39
doesnt it leak?
Old Mar 5, 2009 | 12:33 AM
  #40
SSmoken's Avatar
doesnt it leak?
i think im beginning to notice one. i might see if i can tighten them anymore. if not oh well. its not a bad one and almost goes away after they get hot.
