header bolts
not the case. i thought that too and when i got mine then they ended up not. thats why i reused my stock old rusted sh!tty ones.
I have the supplied pacesetter bolts on both of my cars.
Strange thing is, one set of bolts came too long. I pulled one out of my other car and it was about 1/8" to 3/16" shorter, I just used some aircraft shim washers I had laying around.
If I was in a situation where I needed bolts I'd go to the local Ace hardware. They have metric stainless steel bolts. It would help if they had a smaller than usual hex head to help fit a wrench on. Or get allen head (those are always a higher grade) That and anti-seize.
Also what length bolts have you been using. The ones that I got with Pacesetter are about 1.125 in... it kinda feels like they are bottoming out in the head... ?
As for Loctite, I personally say no. I've had the best luck running the headers a few heat cycles and checking the torque spec. After about the second time doing this, they don't move.
Oh BTW My stainless work headers didnt come with any IIRC and no gay stickers either
Sears bolt out kit works great.
