header bolts
Old Feb 24, 2009 | 09:31 AM
Nick_Rapitis's Avatar
Default header bolts
any one have any trouble with the bolts snapping when taking off the headers to put new ones in and leaving part of it in the block?
Old Feb 24, 2009 | 12:08 PM
fbodyman1026's Avatar
I've never had a problem but soak them with some pb blaster to loosen them up.
Old Feb 25, 2009 | 08:58 PM
bump!
Old Feb 25, 2009 | 09:04 PM
1999FirehawkLS1's Avatar
Never had any problem with mine but ya pb blast them night before and then again before trying
Old Feb 25, 2009 | 09:09 PM
might sound stupid but can i find pb blaster at like autozone? or where?
Old Feb 25, 2009 | 09:21 PM
Mean87SS's Avatar
Yesm. Autozone. Areosol can, yellow cap...
Old Feb 25, 2009 | 09:32 PM
WYATT318MOPAR's Avatar
Don't feel bad factory header bolts are junk. Broke two or three off when I removed the headers on my 6.0 and a 5.3 I used to have luckily the heads were going to the machine shop anyways. The fun part is getting the rest of it out now
Old Feb 25, 2009 | 09:35 PM
99bowtieZ's Avatar
When I got my Z the back drivers side bolt had the head broken off. When I installed my LTs I just got nice bolts for the rest and when I have the heads off next time I will worry about taking it out.
 Michael S. Palmer
Old Feb 25, 2009 | 11:13 PM
you make it sound like its no big deal if one breaks off and you leave it that way...
Old Feb 25, 2009 | 11:16 PM
vsocks1's Avatar
Some do that and claim no leaks. I could not live with a bolt broken off in my head and header not fastened!!!
Old Feb 25, 2009 | 11:19 PM
how could you fix that? take the whole thing apart? how likely is it that this would happen?
Old Feb 25, 2009 | 11:29 PM
vsocks1's Avatar
If you hit them with PB blaster ahead of time most likely you will have no problem. Just use the proper tools and make sure you are wrenching straight.
Mine came out no problem and I was also worried like you beforehand!
Old Feb 25, 2009 | 11:31 PM
what exactly are the right tools? lol is there some special wrench i dont know about?
Old Feb 25, 2009 | 11:38 PM
vsocks1's Avatar
No special tools, just the right rachet & sockets. And, if you can always use a 6 pt socket - less chance of stripping.
Old Feb 25, 2009 | 11:42 PM
yeah i should have all the tools i would need...you know where i can find a good write up?
Old Feb 26, 2009 | 01:11 AM
SSmoken's Avatar
i broke one off in the head. after the header swap i put the stock ones back in. i might get some new ones when the weather is nice and swap them out.
Old Feb 26, 2009 | 07:24 AM
how did you fix it?
Old Feb 26, 2009 | 07:58 AM
03Sssnake's Avatar
on fixing it...well if your lucky and I never am, the bolt snapped near the head/nut. If that is the case you can remove the other bolts and pull the header towards the inner fender, then clamp down on whats left of the broken bolt with some vice grip pliers and spin it back out.
Old Feb 26, 2009 | 08:07 AM
and if its stuck down in the block? just s.o.l.?
Old Feb 26, 2009 | 08:25 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If it is stuck in the head, you can try an EZ out (may or may not work), and if that doesn't work, you'll be pulling the head to drill it out if you want it fixed. Any competent machine shop would be able to do that, but with the head still attached to the block, it would probably be impossible to have enough room to get the right tools in there (in other words, take the damn thing off).
