What qualifies as all bolt-ons?
Old Oct 13, 2003 | 11:54 PM
ShadowLightCSU's Avatar
Default What qualifies as all bolt-ons?
Just in the off chance I'm missing something, what qualifies as all bolt-ons?
Old Oct 14, 2003 | 12:20 AM
FAST LS1's Avatar
Default Re: What qualifies as all bolt-ons?
Full bolt-ons anymore is a lot of stuff:
FTRA, SSRA or some type of ram air
Lid
Larger MAF
Fernco coupler
Porter Throttle body
LS6 intake
Headers, full exhaust
Underdrive pulley
Electric water pump
Old Oct 14, 2003 | 02:19 AM
1jfuddle's Avatar
I would personally argue the larger MAF. It is widely seen as useless and in a TON of cases causes more harm than good.
Other than that, that list seems right.
On the other hand, my heads bolted on...does that count...hehe
Old Oct 14, 2003 | 02:34 AM
Cal's Avatar
Cal
160 T-stat with re-programmed fans or fan switch.
Old Oct 14, 2003 | 02:46 AM
soundengineer's Avatar
basically bolt ons are anything you can do with a normal set of wrenches or sockets...with no specialty tools....meaning average joe and his household set of wrenches will work.
Lid
Larger MAF
Fernco coupler
LS6 intake
Underdrive pulley
Electric water pump
and dont forget removal things too(of course some tuning may be necessary)
take off egr and air system
remove the ac system for weight reduction.
do the short belt mod.
do the bump stop mod when you port and polish the throttlebody
and if you port the maf-DEFINATELY you will NEED TUNING. it will lean out your car dangerously far...
subframe connectors(usually need to be welded in place for the best results)
strut tower brace....
if its a 2000 or before you do the ls6 intake...and while you're at it do the ls6 pcv conversion too..easy to do at the same time..and use a chisel...not a dremel...and gaffers tape works the best to seal up all the holes befor working on it...plus lots of rags and paper towels and...clean...clean...clean...clean...clean...clea n...clean...
of course some looks things too...
hood pins...stripes...if its a camaro..remove that dam black fascia..theres a cooler look underneath(unless your state requires a front plate)
paint everything you can to match the car..or contrast the car to make it look sharper...
put in an electric antenna
do the car stereo mod....
you can shorten the stock stick by buying a dye to cut threads further down than the stock location(by over 4 inches!!) and cut off the excess with a sawz-all....then back the dye of to clean up the threads...(you might need the help of a really large adjustable wrench(thats what I used)...instant shorter shifter...well...a good 30 minutes....
Old Oct 14, 2003 | 03:29 AM
FAST LS1's Avatar
I wouldn't run a larger MAF either without tuning, but it is a bolt on so I included it to make it a full bolt-on list.
Old Oct 14, 2003 | 07:38 AM
HumpinSS's Avatar
Cut out
Old Oct 14, 2003 | 07:46 AM
Dragaholic's Avatar
9 Second Club NA
How about anything that doesnt touch motor oil.
ram air
lid
MAF sensor and ported ends
high flow bellow
ported/polished throttle body
intake manifold
headers
plugs
wires
pulley
injectors
water pump
high flow air filter
free mods
exhaust (catbacks, cutouts, duals, etc.)
Old Oct 14, 2003 | 08:51 AM
Paul F's Avatar
That's the way I look at it too.
Old Oct 14, 2003 | 02:37 PM
mike c.'s Avatar
i see one guy added the short belt mod and another added a cutout. well i just tested both at the track saturday the 11th,and i gained NOTHING from either one.
Old Oct 14, 2003 | 02:42 PM
foff667's Avatar
LS1TECH Sponsor
weight loss can be one of the biggest factors in the equation if you look at the guys running #'s they've all but their cars on a diet...and some even put themselves on one for that extra lil' bit and did everyone forget:
CONVERTER
ususally thee best gain you can get as a bolt on with an auto hehe
lata
bill
Old Oct 14, 2003 | 02:43 PM
foff667's Avatar
LS1TECH Sponsor
rims and tires too as these can save u upwards of 50lbs off the entire car. And let you hook alot better
lata
Bill
Old Oct 14, 2003 | 03:25 PM
Colonel's Avatar
Anything you can do without taking the valve covers off. Oh, and no nitrous or forced induction.
Old Oct 14, 2003 | 04:36 PM
WILWAXU's Avatar
That's basically how I run THE List
Quickest STOCK INTERNALS List
*Bolt on's ONLY. Stock internals motor, intake to oil pan, stock long block. LS6 intake swaps allowed.
Old Oct 14, 2003 | 05:57 PM
FAST LS1's Avatar
WILWAXU I've wondered about replacing things such as valve springs and pushrods but with new stock parts? Is it still elligable to be "internally stock" if you replace those?
Old Oct 14, 2003 | 07:58 PM
BigPlanTransAm's Avatar
i would think so. but if it were me and i broke something i know I would want something better/stronger for the piece of mind instead of bragging rights for be "stock internals"
Old Oct 14, 2003 | 08:20 PM
avezz28's Avatar
Gears, clutches, convertors, headers and weight reduction are some big time bolt-ons.
Old Oct 14, 2003 | 08:34 PM
WILWAXU's Avatar
Technically yes. This list, like all things on the internet are based on a underlying trust. But, haven't seen many people put a motor back together.. completely stock
Old Oct 14, 2003 | 08:42 PM
onebadz's Avatar
Converter defiantly
Old Oct 15, 2003 | 08:25 AM
ZDOG's Avatar
if it cant touch oil than i think our intakes should be excluded!
