How do you get these friggin spark plugs out!!!!!!!!!!!!
ok... well, i tried, and a buddy tried... the fuggers are in there tight...
it's to the point that I'm worried if I turn the socket wrench any more something will strip/break...
what to do... anybody else run into this problem? If I break something off in my AFR's i'm gonna be pissed...
I don't know why people put plugs in any more than finger tight, then literally a little ***** snug with the ratchet, I've been doing that for the past 8 years and my plugs come out with one hand and hardly any effort.
I'm wondering if I should get the engine nice and hot before trying... seems like i heard somewhere heat will help...
also, I took the car out for a spin tonight... sputters bad when "on it" full throttle... like it's missing or something... got a few pops from the exhaust...
anybody else think that sounds like a fouled plug or something...?
You're misfire causes the backfire and pops out the pipes. The fuel is still going in there, then when it does finally fire the mixture...it pops.
This is how I get to my back 2 plugs on the passenger side, they're out and the new ones in, maybe 15 minutes. The drivers side is literally easy and I can do them all in about 15-20 minutes with normal sized ratchet handles.
I think someone kind of screwed you by tightening the **** out of them when they put them in.
Passenger side, back 2 plugs:
![](http://i300.photobucket.com/albums/nn13/slipperyls1/1sparkplug.jpg)
lol... you don't have to worry about the anti-seize.... I'll cake so much of that on there after this!
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I found the best lubricant for stuck stuff is master blaster. but the easiest way to get the plugs out for me, is a swivel head spark plug socket from craftsman. i was going to say if your car is very cold, try warming the area up too, but you are in phoenix so i doubt thats the problem.
worst case, use and impact and if the threads are messed up helicoil it.
#33
That was my thinking as well... but then again... if you think about water in your freezer, when it gets cold and turns to ice, it expands... so... i dunno... I'm still sick as a dog, but thinking by Wednesday I'll hopefully get to feeling better and go give it another shot... we'll see...
#34
Long handle swivel 3/8 ratchet, maybe a short extension on the socket.
I did all 8 in a little over an hour yesterday. The longer ratchet helps alot. The hardest part was removing the last coil pack bolt on the passenger side.
I can do the other car(LT1) in 45 minutes.
#36
Steel expands less than aluminum when heated. I assume your plugs have steel bases.
When you heat a plate with a hole in it (i.e. Heads with a spark plug screwed into it) the hole expands in diameter at the same percentage as the whole part expands.
So long as the spark plug base and heads are made of a different material, heating or cooling will have an effect.
If the plugs have steel bases, and the heads are aluminum, then heat will definitely help you get them loosened up.
#39
Heat would help if you heated the engine and then let everything even out in temp by letting it sit for 10-15 mins.
Aluminum expands almost twice as much as steel so if both were the same temp the spark plug would come out easier.
