Porting stock intake?
Old Mar 2, 2009 | 04:13 PM
redlineracing's Avatar
Default Porting stock intake?
Hey guys.
I planned on putting an ls6 intake on my car. However, the one I purchased did not have egr provisions. I need one that does.
My question is, should I ge my ls1 intake ported? Will that be plentiful for my current mods?
mods are in my signature.
Old Mar 2, 2009 | 05:49 PM
Wiktorek25's Avatar
i believe that there is almost no room for porting on ls1 intakes, as theres no material to remove. A ported ls6 would be better.
Old Mar 2, 2009 | 05:58 PM
badazz99ta's Avatar
why dont you just get rid of your egr system?? all you have to do now is put a block off plate on your manifolds. and if your headers are set up for egr as well, just transfer that plate to them.
Old Mar 2, 2009 | 06:04 PM
Because I am in the U.S. Navy and I will most likely be in California next year
Old Mar 2, 2009 | 06:23 PM
badazz99ta's Avatar
ahhh, it all makes sense now. haha. i take granted of the fact that i dont have emissions testing.
i wouldnt worry about porting the ls1 intake. who did you buy it from. if it was from a store and not a person, then i would call them and explain what happened. im sure they would understand.
Old Mar 2, 2009 | 07:18 PM
I bought it from a forum member, That is no problem, I actually already re-sold it. Lost money on the deal, but hey **** happens.
Old Mar 2, 2009 | 08:16 PM
greatskiiiier's Avatar
drill a hole in the ls6 and epoxy away
Old Mar 2, 2009 | 08:19 PM
NemeSS's Avatar
very bad idea
just go with a 78mm FAST and use the egr, or try to find a egr ls6 made by SLP. good luck with that.
Old Mar 2, 2009 | 08:21 PM
I think I am just going to wait until I do H/C and get a F.A.S.T...
Old Mar 2, 2009 | 08:24 PM
NemeSS's Avatar
makes sense,
fast allows the use of egr, even the 90mm version
Old Mar 2, 2009 | 08:35 PM
LS1nut377's Avatar
ahh that sucks im glad my state doesnt do testing yet! good luck
and i wouldnt touch the ls1 manifold.
Old Mar 2, 2009 | 09:08 PM
Mean87SS's Avatar
Don't waste the time on the LS1 mainfold... get a LS6 and bolt on...
Old Mar 3, 2009 | 07:14 AM
no seriously, drill a hole in the ls6, theres many ways to go from there, "epoxy away" is the simplest, but yes dumb... you can put a brass fitting into the plastic, or tap the plastic, sleeve the plastic with steel, many options
Old Mar 3, 2009 | 08:08 AM
badazz99ta's Avatar
he has already sold the ls6
Old Mar 3, 2009 | 05:26 PM
therealcreeper's Avatar
slp sells an ls6 intake with egr
kinda pricey but cheaper than a FAST
Old Mar 3, 2009 | 06:06 PM
SOMbitch's Avatar
LPE used to sell an EGR adapter kit for $50 but not sure if they still do in case anybody else needs one......
Old Mar 3, 2009 | 09:36 PM
^ i looked, i couldn't find it anymore
Old Mar 3, 2009 | 10:48 PM
Damian's Avatar
LSX Mechanic
Do not waste your time trying to port an LS1 or LS6 intake. More than likely you're going to lose power, and money.
Either leave it alone, or save up for an upgraded part that coincides with the emission requirements of your location.
