Did I do something to my fuel rail to make it leak.
Old 03-11-2009, 12:21 PM
IRONFIST's Avatar
Default Did I do something to my fuel rail to make it leak.
I got in my car today and thought "hey it sure is burnin rich today" (I could smell the gas). Then I noticed a huge amount of evaporation from under the hood.
There is a massive fuel leak, pointed out with the arrow.
I got no idea how to fix this, or if I did something wrong when I took the intake off?
Any ideas?
Old 03-11-2009, 01:05 PM
Magic Man's Avatar
May have tore an O ring or injector not seated.Loosen up the fuel rail and see if the injector will seat if it does then check the rings.I know Jeeps had a problem of the injecters cracking and leaking.
Old 03-11-2009, 01:15 PM
SweetS10V8's Avatar
Yup, time to pull of the rail and inspect the o ring
Old 03-11-2009, 07:22 PM
IRONFIST's Avatar
I basically did an intake swap...
The leak is occuring inbetween the two sections held together by this clip.
Old 03-11-2009, 09:51 PM
Mart00SS's Avatar
Get a set of orings from your local parts store, its pretty cheap. You actually need two sets. One set is 8 o rings and there are 2 o rings per injector (16 total orings). Since you have to pull the fuel rail off anyways you might as well replace all of them so you know theyre all good. Just be sure to lube up the new o rings before trying to seat the injectors into the manifold or the rail. Pretty cheap and easy fix. I replace all of mine when I installed my ls6 mani.
Old 03-13-2009, 09:27 PM
SweetS10V8's Avatar
At the o-ring, imagine that
Old 03-14-2009, 09:53 AM
01ssreda4's Avatar
yeah replace em all, cheap insurance.
Old 03-14-2009, 10:45 AM
Restricted User
socmguy's Avatar
Good thing you caught that before your car burned down! Buy the O ring set from GM and lube them before you push them in.
Old 03-14-2009, 07:59 PM
Sbertolone's Avatar
unless i know the last time i changed the injector oring, i always buy the oring kit just as safe insurance.
