Question on Headers and EGR
Old Mar 13, 2009 | 06:42 PM
ReApEr75's Avatar
Default Question on Headers and EGR ASAP!!!
i have kooks long tube headers and on the passanger side i want to know what you guys did with the egr tubes that went into the stock exhaust manifolds, since there are 2 on the passenger side one is longer then the other, did you bend them back a little or push them back so they can fit....just wondering so i can get and idea on what to do
Old Mar 13, 2009 | 08:48 PM
waldershrek's Avatar
Are trying to hook them up or not use them. If you don't want to use them get block off plates for them
Old Mar 13, 2009 | 08:59 PM
shaun's Avatar
there should only be 1 egr tube and the other 1 is part of the air system.
if you want headers you can get the ones with the hook ups for the air and egr and if you remove those systems later on you can get the block of plates or just do it at the time you install the headers and get the race versions
Old Mar 14, 2009 | 06:27 AM
ReApEr75's Avatar
i understand that but i want to hook them back up for the time being and was wondering if they just bolt right back into place or do i have to adjust the pipe for both the egr and air intake for that passanger side?
Old Mar 14, 2009 | 09:04 AM
Unertl42's Avatar
they should bolt right back into place
Old Mar 14, 2009 | 05:04 PM
ReApEr75's Avatar
BOth ports are on the passenger side header point upwards, how do you put them both on?
