Water temp sensor idea?
Indicated by arrow where I want to put it:
Or get the adapters to install it into the rear passenger side head?
You need to keep the stock one for the engine computer.
That idea you got there would work if you could screw the fitting in further. No matter how you do it it's going to be reading conducted heat, which is not accurate at all in that type of set up.
I have autometers recommened LS1 adapters and temp sensor and the sensor does not extend into the coolant. In fact theres only a 1/8 or 3/16 hole that exposes the sensor to the coolant and as you might guess it reads low compared to the factory gauge, and hp tuners scanner.
I'm wondering this, the TB hose come from the coolant crossover and that comes out of the heads right?
I've been considering moving my sensor to a tee in the TB coolant hose.
If you have a "too hot" issue in the head where the temp sensor is now, fix that issue.
Not that any of this even matters, filling the trans cooler with water and relying on conducted heat is going to be such a slow transfer, it might read right on long trips, even then I doubt it.
Maybe on a blistering hot day in stop-and-go traffic it might reach a high temp and stay open, but if that happens you'll be on your way to overheating.
But Yes. T-stats do not stay open and they do not stay closed all the time. They are a thermostat, so they open when the heat reaches a certain temp, then the hot coolant from the engine and heads flows into the radiator and trades places with the cool coolant that was sitting in the radiator wiating to go into the engine/heads. As the cool coolant makes a complete circuit and comes back around to the t-stat again, the t-stat senses the cooler coolant flowing past it and closes. Then the hot coolant in the radiator gets its chance to cool off, whether from ram air from the lower air damn from forward movement OR from the electric fans that were on when that hot coolant was in the head telling the coolant temp sensor to turn on the fans.
Check to see if your t-stat is working. Take it out and put in a pot of boiling water, see if it opens when it should. Use a food type thermometer to watch the temp as it rises. Just hold the thermometer next to the t-stat in the pot as the water gets hot. You should see that little dick start to come out of the t-stat.
Leave the fan setting alone. Like I said, my fans hardly ever come on, ever. I don't remember tha last time I heard them. Maybe thats why they are original fans from 11 years ago.
Meaning if it did stop flowing 100% it would be closed.
Go find someone else to follow around, WTF is your problem you stalker.
You ******* **** sucking pile of dog ****.
When mr administrator sees this, don't even ******* bother messaging me, I don't want to be a part of this kind of bullshit, just ban me and don't waste your time sending out a message.
