High Quality Catch Can - Pics Inside
Old Mar 23, 2009 | 12:35 AM
rich Z's Avatar
Originally Posted by Soul TKR
and what personal experience do you have to back up that statement?
Well lots of oil in the intake still.
Old Mar 23, 2009 | 01:21 AM
Soul TKR's Avatar
ok...... but how does that lead to the assumption that this one does the same as that one?
Old Mar 24, 2009 | 07:43 PM
rich Z's Avatar
It's the same design.
Old Apr 18, 2009 | 08:52 PM
Mike94ZLT1's Avatar
Originally Posted by 405HP_Z06
Probably more than you want to know, but this thread has it:
https://ls1tech.com/forums/generatio...l#post10918720
RevXtreme or Saikou Michi
The Rev Xtreme one does not work.
Old Apr 18, 2009 | 08:54 PM
Mike94ZLT1's Avatar
The Rev Xtreme one does not work... Not only did it absolutely destroy the hoodliner in my C5, but it has not caught anything. The intake in my 382 was soaked with oil. I pulled it today and put a CCA can on there, hopefully it works a little better.
Old Apr 18, 2009 | 11:32 PM
Adam86's Avatar
I think you're the first person I've heard say the Rev Xtreme cans don't work well. Everything I've heard has been good but DAMN are they marked up like hell.
Old Apr 18, 2009 | 11:36 PM
405HP_Z06's Avatar
Please elaborate on configuration detail of the PCV system with the RevXtreme can. Please post pics.
Old Apr 18, 2009 | 11:42 PM
405HP_Z06's Avatar
When it comes to catch cans, you get what you pay for.
Old Apr 19, 2009 | 12:03 AM
chrs1313's Avatar
i paid 110 for mine and i still got oil in the intake...had to take matters into my own hands...
post 12
https://ls1tech.com/forums/generatio...atch-cans.html
Old Apr 19, 2009 | 12:42 PM
Mike94ZLT1's Avatar
I had a hose going from the LS6 valley cover to the inlet on the top of the can. I then had a hose going from the PCV valve built into the can (horrible design, how the hell do I change it if it goes bad? ) to the nipple on the side of the intake behind the TB. I could wipe more oil out of my intake with a paper towel than there was caught in the can after a whole summer of driving.
Old Apr 19, 2009 | 02:50 PM
405HP_Z06's Avatar
01-03 or 04 LS6 valley cover? How did you have the clean side of the PCV system configured?
Last edited by 405HP_Z06; Apr 19, 2009 at 07:44 PM. Reason: RevXtreme can detail error
Old Apr 19, 2009 | 03:17 PM
  #32
Mike94ZLT1's Avatar
01-03 or 04 LS6 valley cover? The RevXtreme can doesn't have a built-in PCV valve. The port on the side has a one way check valve inside the can.
04 Valley cover. A one way check valve basically is a PCV valve, and on mine it is glued into the side of the can.
Old Apr 19, 2009 | 03:33 PM
  #33
schuby87's Avatar
They told me it does.
Old Apr 19, 2009 | 06:18 PM
  #34
405HP_Z06's Avatar
A one way check valve is not a PCV valve. A PCV valve is a variable orifice valve. A one way check valve is a full flow valve in one direction.
How is the clean side of your PCV system configured?
Edit **According to Tracy at RevXtreme, his can does have a PCV/one way valve. My error.**
Old Apr 19, 2009 | 07:29 PM
  #35
TLewis4095's Avatar
Yours would be the first complaint to date out of thousands sold....it could have been faulty or you may have had it configured wrong or it would have caught most everything period. Over 50 a week go out through various vendors, many supporting vendors on this site. Also, the hoodliner would be a clearance issue....it MUST be mounted in the bottom-most threaded hole in the pass side cyl-head, and the old bracket was easy to bend for clearance. The new one is 1/4 inch alum stock so is not easy to bend but is precision punched by a CNC machine now instead of 1/8" jig bent on the early models. The PCV/check valve (yes it does both...just try and blow through it in reverse to see & it meters tha amount of vac pulled to the same spec the OEM ones did) is easily replaced if needed. It is bonded in with a semi-permanent epoxy and easily twist's out for replacement if needed....which RevX does for free if ever needed (customer pays shipping to, and they cover it back).
Also, since it has a money back guarantee why would you not call tech support & return it in the event it was faulty? (bound to be a defect in some over that volume).
The CCA piece is beautiful and super high quality, but at 1/2 the capacity you will only have 1/2 of the condensing effect to seperate the oil mist/vapors. I'm willing to bet you have a ring/piston/cyl bore issue and have excess blow-by causing oil to enter through the throttle body due to reversion pulses if you still have an issue.
Good luck!!
