***Need you help**Hooker catback fit cme?
Old Mar 21, 2009 | 09:29 AM
hmorris7000's Avatar
Default ***Need you help**Hooker catback fit cme?
I have cme on my ss and want to knowif the hooker catback pipes will line up with my cme, thanks in advance for your help
Old Mar 21, 2009 | 09:49 AM
black01_WS6's Avatar
I am almost 99% sure it won't. I have the hooker on mine and can't see how they could hook up to a CME w/o hurting the flow
Old Mar 21, 2009 | 01:06 PM
thanks why do you think they wont?
Old Mar 21, 2009 | 03:02 PM
the muffler is pretty dam big, and exhaust pipes would have to make about a 45 degree or more bend to get it to the middle- hence hurting power. I could be wrong though. I will be under my car tomorrow and will take a look
Old Mar 21, 2009 | 03:55 PM
thanks my cme tips have the 90 degree bend pipes my question is, will the 90 degree pipes line up with the hooker pipes coming out the muffler check my pic
Old Mar 21, 2009 | 05:42 PM
you would still need a 90 degree bend to make it fit. what is the dimension between the pipes? I will measure my muffler tomorrow for ya if you want me too.
Old Mar 21, 2009 | 08:45 PM
1Bad00SS's Avatar
Any competent exhaust shop could do it easy..
Old Mar 21, 2009 | 09:49 PM
Full-Force's Avatar
looks close
Old Mar 22, 2009 | 07:23 AM
could you measure it from to pipe to pie for me ? thanks ill check car tomorrow its in storage so when i check it i will also get the measurements
Old Mar 22, 2009 | 07:57 AM
9000th01ss's Avatar
it'll work. i have an ss with a cme and a z28 with a hooker muffler and stock tail pipes.
Both measure 3' between the pipes. Get someone who can bend a pipe into a 90 and it can be made to work. That cme pic you have needs a 90 bent on two sides.
To someone who knows what they're doing it's considered very easy.
Old Mar 22, 2009 | 01:57 PM
Thanks
Old Mar 22, 2009 | 02:25 PM
9000th01ss's Avatar
I got your pm, can't do that, sorry.
All you need looking at the cme pics and assuming you have a muffler installed, is two pieces of pipe bent at 90* to connect the cme to the muffler. My cme came with them. With the hooker muffler you may need these parts custom made anyway.
Maybe you can get a better idea with the pics.
Old Mar 22, 2009 | 03:46 PM
i have the 2 90 degree bends that connet to the tips my question was does the hooker line up with the cme tips and the 90 degree bends or do you have to mod the pipes coming out the hooker some kind of way
Old Mar 22, 2009 | 05:37 PM
9000th01ss's Avatar
It'll work, I wouldn't expect it to slide together without modification.
I measured both mufflers, they are within 1/2" in outlet width, I measured but couldn't get a good pic, I tried, not having the best of days otherwise either.
Old Mar 22, 2009 | 08:19 PM
Full-Force's Avatar
If the muffler widths are that close then why cant you just cut part of the hooker tailpipes off and weld then to the cme pipes. I dont see where the 90* bends are needed.
Old Mar 24, 2009 | 01:19 PM
thanks for all the help guys so you are sying that the 90 bend needs to come from the muffler and the one from the cme (those 90 beds come with tips) thanks again for all your help
Old Mar 24, 2009 | 03:49 PM
12secSS's Avatar
You are an idiot! I have the CME on my Hooker exhuast. The factory CME has the tailpipes bend at a 90 degree angle toward the center of the car, where the CME tips are. The cat-back tailpipes (OEM and aftermarket) are at the same locations. All you need to do is trim the tailpipes a bit under the rear bumper to avoid having the CME tips hanging out past the bumper. Any exhaust will work with a CME!
/thread
Old Mar 24, 2009 | 06:22 PM
/thread
thanks
Old Mar 25, 2009 | 08:10 AM
2002_z28_m6's Avatar
It works. That is what I have. It was really pretty easy to install.
