FAST 92 Intake Bolts Loosening Up
Just installed a Fast 92. I am having problems keeping the bolts torqued down. I did not put loctite on them the first time and figured that was the reason. So I put blue loctite on them and torqued them to the recommended 89 in/lbs. I drove it about 20 miles to work and back, checked them, and they loosened up again. Would checking them while it was still hot make a difference? Should I go with the red loctite? Thanks for any help
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Just installed a Fast 92. I am having problems keeping the bolts torqued down. I did not put loctite on them the first time and figured that was the reason. So I put blue loctite on them and torqued them to the recommended 89 in/lbs. I drove it about 20 miles to work and back, checked them, and they loosened up again. Would checking them while it was still hot make a difference? Should I go with the red loctite? Thanks for any help![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
