Help! Safe method to raise car for header install
Old Apr 16, 2009 | 11:15 AM
dlandsvZ28's Avatar
Originally Posted by Lopoetve
I was gonna say - I've only got 35k on the car, so I figure the stocks are good for a bit more still
True - maybe your plugs don't need changed now but when you do change them later on you will CUSS yourself (many times over) for not changing the plugs now.
Old Apr 16, 2009 | 01:10 PM
pontiac1998's Avatar
yeah it is def easier to do it with the headers out of the way...but it does come down to money i guess...but 75 bucks for wires and plugs on ebay even is just cheap insurance
Old Apr 17, 2009 | 11:27 AM
Lopoetve's Avatar
I have every intention of having someone else do it.
I learned long ago that it's not worth my time to try and replace the plugs on an F-body. Bother that. That's the ONE maintenance item I won't do.
If I don't have to remove them to get the headers on, I'll have them done when they're due, by someone I'm paying to suffer.
Old Nov 2, 2009 | 02:15 PM
jimmypop13's Avatar
How are you guys jacking up the car on the k-member when the back wheels are on ramps? I can't get under my front bumper at all when the back is on ramps
Old Nov 2, 2009 | 04:06 PM
dlandsvZ28's Avatar
You have to drive the front onto a pair 2x8's or maybe even four if your car is real low. Or jack each side up and slide 2x8's under each front tire. That should raise the front high enough to get a floor jack under the air dam and under the k-member.
Or if you ramp from the front you might have to repeat the process on the back if you want to raise the car from the rear too if the front is already on ramps in order to get a jack under the rear end pumpkin. Or jack from the side and slide boards under the rear tires.
I have a 2 sets of 2 X 10's each cut at a 45 degree angle on the front edge. The tires drive up easier cut at 45 degree. Boards want to slide forward on slippery concrete.
If fact I just got done raising and lowering my care to adjust pinion angle.
Old Nov 2, 2009 | 04:46 PM
bdrussell's Avatar
Originally Posted by texas99Z28
Going to try installing my headers. I know the car has to be raised pretty high to do the install. What is a safe method to do this? I have seen a couple of pictures that looked VERY unsafe. Such as 4 x 4's under and on top of the jack stands. Don't want to get killed! Thank you
Here are some examples of different ways to get under your car.
Old Nov 2, 2009 | 06:34 PM
jimmypop13's Avatar
Old Nov 2, 2009 | 06:38 PM
toslow5o's Avatar
get a good look at the dipstick b4 u pull it out. the only frustrating part of my entire install was putting it back in.
Old Nov 2, 2009 | 06:45 PM
toslow5o's Avatar
when i first got my car i thought the same but when the shop wanted over $500 i changed my mind.
it's much easier to change them after a header install. what makes the plug change a nightmare is the emissions junk, manifold heat shields and the passenger side coils. removing the entire valve cover takes 5 minutes and gives u tons of room
plus there's a good chance u will break a few plugs during the header install.
Old Nov 2, 2009 | 06:50 PM
808_ss's Avatar
is it possible to drive up 4 ramps?? or safe?
Old Nov 2, 2009 | 06:56 PM
jimmypop13's Avatar
Huh? How would you do that? We own cars, not trucks
Old Nov 2, 2009 | 07:13 PM
  #32
dlandsvZ28's Avatar
These stands are safe - 6 ton limit - Harbor Freight.
As you can see in the pic my stands are set to the lowest setting. Twenty-four inches is max. You will need an industrial strength jack however to raise the car 24 inches. You have to raise the car in steps (3-4 inches at a time) unless you have two jacks - one in the front, the other on the rear.
http://www.flickr.com/photos/1835930...7602956888623/
Once you get the car raised - tires and rims under each tire is a safety net if the car actually slides off the jack stands. But that shouldn't happen if you put the jack stands under the axle tubes on the rear end. The jacks stands under the rear axle tubes should lock the car in place keeping in from shifting forward or backward or sideways on the front.
I would never use cinder blocks - they break too easy.
Old Nov 2, 2009 | 08:00 PM
  #33
Chrome355z's Avatar
I had my car on 4 x 6 ton jack stands and had a cinder block underneath each wheel. There was a little bit of a gap between the cinder block and the front tires (rear was sitting on them), but I just had those there for piece of mind if for some reason the quality control guys was out to lunch the day sears mfg my jack stands.
Old Nov 3, 2009 | 02:48 AM
  #34
808_ss's Avatar
i meant by securing 4 ramps to the ground infront/behind the wheels? can it be done, climb all 4 ramps and have the car sit on them? just a thought
Old Nov 3, 2009 | 08:09 AM
  #35
jimmypop13's Avatar
That's what I thought you meant but you can't get ramps in front of the back wheels
Old Nov 3, 2009 | 08:15 AM
  #36
dlandsvZ28's Avatar
You will be unable to drive the car unto the ramps front and rear at the same time.
If fact if your car is lowered - dependent upon height of the ramps - you might have to drive unto 2x8's first raising the car and then from the 2x8's continue up the ramps in the front.
After the car is on ramps in the front, jack the car under the rearend pumpkin high enough and then slide the ramps under the rear tires.Do it all of the time.
Be careful when doing this because as you raise and lower the jack the car will be forced to roll forward or backward as you raise the jack. If raising the rearend first always block the front wheels to keep the car from rolling forward. When lowering the rearend first, always block the front wheels on the rear side to keep the car from rolling backward.
Old Nov 3, 2009 | 08:45 AM
  #37
Fabian's Avatar
I use 4 12x2s for a SOLID wood base under each tire. I also put jack stands up as extra insurance.
Old Nov 3, 2009 | 05:57 PM
  #38
Lopoetve's Avatar
Having never done it before, it'd take me a couple of hours to get the valve cover off :p
I don't even know how to get the coils off.
Old Nov 3, 2009 | 07:16 PM
  #39
jam01's Avatar
dig a hole in the ground, deep enough so you can stand in it.
Old Nov 4, 2009 | 07:57 AM
  #40
Fabian's Avatar
Everything comes apart with bolts and nuts. Get a little repair manual and have at it. I had never even taken an intake manifold off up until a month ago, and the wife and I just finished replacing the passenger side head gasket, cam swap, springs, pushrods, etc etc etc. It wold take you about 10 minutes to take a valve cover off. Do eeet
