View Poll Results: Is it worth buying SS headers ONLY lookin for powers
Pacesetter 1 3/4
0
0%
Kooks 1 7/8 stepped to 2in with 3.5 collectors
0
0%
Voters: 0. You may not vote on this poll
Header to go with?
Old Mar 24, 2009 | 03:26 PM
1999FirehawkLS1's Avatar
Default Header to go with?
How much more power will i make doing H/C buying the Kooks 1 7/8 stepped to 2in w 3.5in collector and 3.5in ORY over using pacesetters?
Do i buy the pacesetters and just save the money?
I really wanna know what the HP diff will be with a dyno tune in the end...?
Old Mar 24, 2009 | 03:29 PM
blown03mustang's Avatar
with just h/c you might pick up a lil more all over the curve with the kooks vs the pacesetters but those headers would really shine if you threw some spray on that motor
Old Mar 24, 2009 | 03:33 PM
Been thinking about spraying to some day w it but that would put my set up over 500HP to wheels on stock bottom end kinda scary
Old Mar 24, 2009 | 03:46 PM
i think you should go with the stepped header and TDs if your goin for a max effort build...but make sure the TDs are mandrel bent! i would check with a few of the sponsors for the big hp kits.
Old Mar 24, 2009 | 03:52 PM
I have read in the stickies TD's dont make as much as a ORY.....i was goin to run a 3.5 ORY w 3.5 I pipe and 3.5 E Cut out
Old Mar 24, 2009 | 04:07 PM
haha that has been and will continue to be debated until the end of time! im not gonna start a war or anything like that, but all the results ive seen pretty much say 9x outta 10 TDs outflow the average Y pipe! but there are Y pipes that outflow some TD setups, ie: the flowmaster merge, but that still only still flows about the same as a TD setup. plus TDs sound 1,000,000,000x better than Y pipes.
Old Mar 24, 2009 | 05:44 PM
Got ya i think its all in the merge colletor of a good ORY pipe ive seen some horrible merges there and i could def see how TDs would be better
TDs on a camero i could see doing cause there are no cut outs ing the rear bumper but on a TA or Fh like mine it would bother me not haven any tips......and getting TDs ran over the axle.....lots of money and PIA
