Throttle body blade hole question
Old Mar 24, 2009 | 09:14 PM
94lt1m6's Avatar
Default Throttle body blade hole question
On the previous tune, I had to drill the hole on the TB blade a little bigger to get enough idle air. Now I got another tune for the bigger injectors, and less restrictive intake, and the car was reving up real high when I let off the gas. So I started filling in the hole, and It was slowly getting better and better. I ended up completely filling it in, and it idles the best now, with that hole completly filled in. Does that sound right? Shouldn't it need at least some air?
Old Mar 24, 2009 | 09:30 PM
vsocks1's Avatar
Hole is not needed nowadays!
Old Mar 24, 2009 | 09:40 PM
94lt1m6's Avatar
Lol how come?
Old Mar 24, 2009 | 10:33 PM
02 BLK WS6's Avatar
Originally Posted by 94lt1m6
Lol how come?
The TB has a set screw that can be turned to slightly open the TB. Most tuners suggest this instead of drilling. Once you drill it is more difficult to take away from what you have done. The IAC can only do so much in either direction.
Old Mar 25, 2009 | 09:28 AM
94lt1m6's Avatar
Yea, but my question is how come mine is completely blocked, and the car runs better. That screw to adjust the TB blade opening is completely closed as well.
Old Mar 25, 2009 | 10:22 AM
vsocks1's Avatar
Lol how come?
Not needed with a good tune!
Old Mar 25, 2009 | 10:52 PM
94lt1m6's Avatar
So my tune is good is the reason?
Old Mar 26, 2009 | 07:17 AM
vsocks1's Avatar
I can't say for sure that your tune is good. All I can say is that with a good tune you don't need to drill holes in throttle bodies....But I can say that your old tune wasn't very good!
Old Mar 26, 2009 | 07:21 AM
Black 99 Bird's Avatar
Air is getting in the engine some how. It does not need much at idle but it does need some. If you are 100% it is not going through the TB maybe you have a bad TB gasket?
Old Mar 26, 2009 | 07:56 PM
94lt1m6's Avatar
Thats kinda what I was thinkin. Unless it is getting through around the blade somehow, the TB gasket looks perfect.
Old Mar 26, 2009 | 09:24 PM
syclone74's Avatar
I have a jantzer 92mm throttle body and the blade does not have a hole in it either, guess they dont need it if the car is tuned right.
Old Mar 27, 2009 | 10:45 PM
JonCR96Z's Avatar
WRONG!!
IAC motor should be kept around 60 counts. That gives it plenty of adjustment to open or close more if needed. In order to accomplish this the hole needs to be the right size.
The throttle blade also needs to be closed to accommodate closed throttle functions in the tune. The PCM can be tweaked to allow whatever, but that's not the correct way to go about it.
