Check Your FAST 92 Bolts?
Sometimes when you tighten the one side the opposite side loosens up cuz it pulls it down more so I tighten the bolts snug, then snugger then to spec and run through every bolt at least twice with the torque wrench so I know any didnt loosen up when I tightened the other ones...
I think you are correct with it being an issue with using the stainless hardware. I'm disappointed to hear loctite did not help - that's what I was going to try.
Also, it may be the gaskets "settling" as already mentioned, but definetly not the torque method. I installed mine per the instructions and went back and double checked that they were all at 89lbs still.
I'll try teflon tape when I get mine reinstalled and let you guys know how it turned out. It's a trick I've learned works pretty well for threads that are on their way out - maybe it will do the same for the stainless issue.
Anyone with the Fast 92 should check their bolts ASAP
Stainless bolts, alum heads, plastic intake... All have different expansion rates...A problem source??
Same thread specs on the bolts as in the heads? [Someone mentioned stock bolts= no problems.]
Does the intake use stock gaskets? If so, are the gasket grooves the same depth as factory intake? Too shallow and you are trying to maintain bolt loading on a "sponge".
Back to huggin' my stock intake!
Replacement bolts are bottoming out???
I have a stock LQ4 intake, and an LS1 intake. I can depth check them. NE1 w/ a FAST check the depth on thiers, for comparison???
